Classic Audi » Technical » Mech/Tech » Engine » Help to locate boost hissing noise
Prev Previous Post   Next Post Next
Old 16-07-09, 12:24 PM   #2
4v6
Check all hoses and connections for tightness.
If theres a bad split someplace, use a can of carb cleaner/brake spray and spray each joint in turn with the engine running.
Any air leaks will show up as a rise in rpms which drop down to normal afterwards.
Dont go mad with it tho else you may set the car on fire.....
Can only be in the induction air path so basically any hose or connection that is on the pressure side of the turbo ( including the intake manifold) is subjected to boost which can bleed off if theres a leak at all.
S6 Boost?? Booty Engine 6 11-11-09 11:27 PM
ur quattro boost setting WR engine Darron Edwards Engine 2 22-10-09 10:38 PM
Where is my boost gone? quattrokid Engine 6 20-09-09 11:07 AM
boost at 1.1bar constant 100turbo c Engine 4 26-03-09 09:04 PM
Hissing fuel pump spaarky Engine 12 27-10-08 10:44 PM
