Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » door rubbing strip bonding seal removal
Old 07-04-09, 05:54 PM   #1
dandan
big gimping
dandan's Avatar
Default door rubbing strip bonding seal removal
how the buggery do you remove the black mastick/bonding seal crap off the car from where the rubbing strips were? hair dryer no good/acertone no good/plyers no good. thinking of using paint stripper heat gun
dandan is offline   Reply With Quote
Old 07-04-09, 06:00 PM   #2
Ah that eternal question.
Wel i pondered very much the same conundrum some years ago on the coupe, result- got it all off but by heck.....
Anyway, i used a stanley blade to shear off as much as i could- took me days and then cellulose thinner iirc- however, i was repainting the panels and id not do the same again.
Stuff like nothing ive ever come across before- i reckon its some kind of epoxy/2 pack derivative but what exactly i dont have a clue. Wish you could buy it tho!
Old 07-04-09, 06:34 PM   #3
gawd knows without lifting the lacquer! I think you've got as much chance as seeing God!
Old 07-04-09, 08:32 PM   #4
moonwatcher
moonwatcher's Avatar
You could try Mastic remover, it dissolves mastic, it might work?
Coupe Quattro 1985
Old 07-04-09, 08:32 PM   #5
kully
kully's Avatar
Its the same stuff as windscreen bonding sealer
Old 07-04-09, 08:45 PM   #6
Ahhhh! Explains why its such a pita to remove then.
Has to be good stuff to stick screens in as the bonded in ones are effectively part of the structural strength.
Does this product have a trade name? And can we get some? Got some Diy thatd work well with that stuff methinks!
Old 07-04-09, 09:10 PM   #7
kully
kully's Avatar
yeah, i think its called sikatac bonding sealer, ive used it for plenty of diy work, ill get you one for the next breakfast meet,
Old 07-04-09, 09:27 PM   #8
Excellente!
Old 15-07-09, 05:32 PM   #9
Dannny
sorry to dig up an old post but did this get solved in the end? because i'm swearing and shouting a lot at a 1mm by 1mm bit of glue that i'm convinced if I can remove it, the rest will follow.
Help?
Dannny is offline   Reply With Quote
Door aperture seal stuartmmcfc Parts Wanted 7 03-08-09 07:15 PM
Rubber door trim/strip Sie! Parts Wanted 10 14-04-09 11:49 AM
Door Strip Adheasive Sie! Bodywork, glass & exterior fitments 2 10-02-09 06:36 PM
Drivers door bump strip a25c Parts Wanted 2 28-09-08 11:58 PM
Door seal Audi 80 Coxy Parts Wanted 2 25-07-07 09:19 PM
