-   Bodywork, glass & exterior fitments (http://www.classic-audi.co.uk/forum/forumdisplay.php?f=34)
-   -   door rubbing strip bonding seal removal (http://www.classic-audi.co.uk/forum/showthread.php?t=4314)
dandan 07-04-09 05:54 PM
how the buggery do you remove the black mastick/bonding seal crap off the car from where the rubbing strips were? hair dryer no good/acertone no good/plyers no good. thinking of using paint stripper heat gun
4v6 07-04-09 06:00 PM
Ah that eternal question.
Wel i pondered very much the same conundrum some years ago on the coupe, result- got it all off but by heck.....
Anyway, i used a stanley blade to shear off as much as i could- took me days and then cellulose thinner iirc- however, i was repainting the panels and id not do the same again.
Stuff like nothing ive ever come across before- i reckon its some kind of epoxy/2 pack derivative but what exactly i dont have a clue. Wish you could buy it tho!
Coxy 07-04-09 06:34 PM
gawd knows without lifting the lacquer! I think you've got as much chance as seeing God!
moonwatcher 07-04-09 08:32 PM
You could try Mastic remover, it dissolves mastic, it might work?
kully 07-04-09 08:32 PM
Its the same stuff as windscreen bonding sealer
4v6 07-04-09 08:45 PM
Ahhhh! Explains why its such a pita to remove then.
Has to be good stuff to stick screens in as the bonded in ones are effectively part of the structural strength.
Does this product have a trade name? And can we get some? Got some Diy thatd work well with that stuff methinks! :)
kully 07-04-09 09:10 PM
yeah, i think its called sikatac bonding sealer, ive used it for plenty of diy work, ill get you one for the next breakfast meet,
4v6 07-04-09 09:27 PM
Excellente! :)
Dannny 15-07-09 05:32 PM
sorry to dig up an old post but did this get solved in the end? because i'm swearing and shouting a lot at a 1mm by 1mm bit of glue that i'm convinced if I can remove it, the rest will follow.
Help? :(
