Classic Audi » Classifieds section » Parts Wanted » Coupe GT door seals
Old 28-12-19, 06:20 PM   #1
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
Default Coupe GT door seals
Hi all
I need to replace the door seals on my GT. Apart from looking rather tired and allowing a lot of wind noise, the passenger side is letting in water (thanks to the never ending British rain!).
Does anyone know where I can source these, either original or more likely an equivalent with the correct dimensions? Assuming quite a few of you have done this, especially when restoring your car!
Cheers
Will
Old 28-12-19, 06:44 PM   #2
droopsnoot
Are they actually damaged? I've had some good results with a product called "Gummi Pflege" on my TT Roadster seals, you rub it into the seal and it has a bit of a rejuvenating effect. Dried up most of my drivers footwell paddling pool, about £8 on eBay for a stick.
droopsnoot is offline   Reply With Quote
Old 28-12-19, 08:44 PM   #3
Hmmmm, that’s interesting, I’ll check that out.... I’ve used creative Vaseline use in the winter to prevent water ingress, freeze and rubber tear in dodgy situations.... Vaseline has many uses in dodgy situations...
Old 29-12-19, 04:40 PM   #4
86audicoupe
Thanks for the tip! No the passenger side isn’t damaged so I think the is worth a shot. Very noisy on that side too but on close inspection the seal doesn’t look rather flat. The drivers side is has a few small tears but hasn’t caused an issue so thought best to leave it for now.
I’ll report back with how it goes
Old 29-12-19, 05:32 PM   #5
tractor Dave
If the snake oil doesn't work, seals+direct have been very good for me
Old 29-12-19, 05:40 PM   #6
86audicoupe
Thanks Dave. I used them before too and they were very helpful. Have you bought the equivalent of door seals from them?
Old 29-12-19, 05:47 PM   #7
Originally Posted by 86audicoupe View Post
……... letting in water
+1 for the Vaseline, I've used silicon spray as well but it's a bit watery and nowhere near as satisfying as rubbing in the "jelly"
You could also try dressing the metalwork outwards so the seal presses harder to the door?
Old 29-12-19, 05:59 PM   #8
tractor Dave
No, not yet but they do have a good range. Only my tractor seals so far and they are excellent.
