Classic Audi » Technical » Mech/Tech » Interior » Door top trims/caps
Old 08-03-17, 12:00 PM   #1
Davids
Default Door top trims/caps
Gents
me again, trying to get the Coupe up together.
Ordered the bits that fit on top of the door and basically seal where the front window drop into the door, its triangular in shape and help that part of the door to seal on the seal.
Sorry its a cockeyed description but I'm not sure what it is called and neither do others as I have seen it called all sorts of names.
Part numbers were 895-867-694-01C and 693 for the other side.
Also I ordered the closing bit of rubber that always seem to go missing according to forums, it closes a gap in the top of the door where the rear of the window drops down, part numbers 895-867-691-01C, this also helps make a seal to the aperture rubber.
The long and short is what a pile of cr@p the parts are from Audi Tradition. For the love of me they don't look right but they have the correct part numbers on them. I have searched but I cant find a nice shot of these sealing pieces actually on the car. Does anyone have a good close up of these so I can see if Audi have actually sent the right piece and how they are meant to fit.
Cheers chaps
David
Davids is offline   Reply With Quote
Old 08-03-17, 12:28 PM   #2
I think you have the right bits, the door card will need to be removed to fit them, the "tails" on the rubbers locate through bits on the door card.
"895 867 691 01C" left front
"895 867 692 01C" right front
"895 867 693 01C" left rear
"895 867 694 01C" right rear
Old 08-03-17, 12:56 PM   #3
Davids
Thanks John, it just looks like the rear ones are not complete, also not havni9ng any on my car I have no idea what an OE set would look like.
Cheers
David
Old 08-03-17, 12:59 PM   #4
sinbin5t
sinbin5t's Avatar
Those are deffo the right numbers that i have given previously, i also pointed out about the door cards being removed to fit them.
Mine are the same parts and are totally correct, just be careful that you don't snap the tails off by trying to pull them in dry, and the old tails are quite often still stuck in the door card
Hope you get it sorted
Old 08-03-17, 01:09 PM   #5
Davids
here you go lads, the front looks right ish, the rear looks nothing like I thought it should.
Front
Rear
Old 08-03-17, 01:21 PM   #6
sinbin5t
sinbin5t's Avatar
Those are exactly the right parts David, have you got the door cards off ?
Old 08-03-17, 01:28 PM   #7
Davids
Going to have a go tonight or weekend, thanks for the comforting words chaps.
Now like I need another job the cam belt has just snapped on my daughters 1.4 Fiesta
Old 08-03-17, 01:37 PM   #8
sinbin5t
sinbin5t's Avatar
Hope you get that sorted too David
I am going to look at the sealing elements on Stormtrooper in a short while David, will let you know the verdict on them
Old 08-03-17, 01:51 PM   #9
sinbin5t
sinbin5t's Avatar
Been for a look and the rears are lumpy wierd looking things , but i also think the tails are a bit wider on the new one's, should still fit though.
Maybe our mate John can put the parts diagram showing these on here.
Old 08-03-17, 02:33 PM   #10
Davids
Thanks for the help.
Stormtrooper ? Starwars ?
