Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » CQ20V rear light sealing
Old 23-01-16, 03:19 PM   #1
ken0204
Default CQ20V rear light sealing
Hi All,
I am curing a leak around the rear lights and there is no rubber gasket between the light housing and the body,just a load of sealant. Should there be a gasket and where could I find one?
If not, what sealant is best?
I have some window frame silicone sealant but it seems a bit rubbery and flimsy so might not be up to it.
Thanks folks.
ken0204 is offline   Reply With Quote
Old 23-01-16, 03:30 PM   #2
quattrodave
I normally use dum dum which comes in a can and can be rolled similar to plasticine and then used to form a worm of sealant in the ridge on the light fitting. Just done a quick search and it appears its no longer in manufacture. someone must make an alternative, whatever you do don't use anything that is a permenant bond as you'll never get the light off again at a later date (tigerseal or silkoflex is a no no).
Good thing about dum dum is that you can remove and reuse it.
this should work as its similar but much more expensive ! http://www.ebay.co.uk/itm/Eastwood-F...AAAOSwNSxVXFy8
or this http://www.ebay.co.uk/itm/DUM-DUM-DU...25.m3641.l6368
Old 23-01-16, 05:31 PM   #3
moonwatcher
moonwatcher's Avatar
I've just fitted new rear clusters on my cq and that came with similar to the ebay dum dum
Coupe Quattro 1985
Old 23-01-16, 05:48 PM   #4
4v6
I used something called butyl tape which you can get from VW as per the oem stuff.
Bit expensive mind you as they only usually sell it in 6 or so rolls.
Old 23-01-16, 07:15 PM   #5
Andy10v
Andy10v's Avatar
The OEM stuff is sealant on a roll as Tony says.
You can get individual rolls of butyl tape on ebay, just make sure you get square/round stuff, not the wide flat tape.
2005 350z GT
Sold-1993 ABY coupe
Old 25-01-16, 09:02 AM   #6
ken0204
Default Light unit sealant
Cheers for the advice guys- I have ordered some butyl tape.
ta
