Members: 19,795 | Total Threads: 40,092 | Total Posts: 471,099 Currently Active Users: 2046 (0 members and 2046 guests) Welcome to our newest member, WatWat |
any idea what i need to correct the intermittent working of the central locking on the audi 90?
the driver's side rear door button goes down sometimes and the boot has stopped locking with the central locking all together now. rubbish! do you think that the central locking solenoid actuators are gubbed in these two areas? thanks, craig ![]()
1997 Audi S6 Ruby Red Last edited by geneandbolly; 17-08-13 at 12:33 PM. |
#2 | |
#3 | |
thankfully, not everything in life is as troublesome as a classic audi...!! ![]()
1997 Audi S6 Ruby Red |
Normally, the pump should run for a few seconds until all the locks have actuated, if an actuator doesn't work when others do then it could be stuck or it's pipe is crushed stopping the flow, if the pump continues to run for up to 30 seconds then a pipe is off somewhere.
1992 80 quattro 20vt |
#6 | |
![]() It's all vacuum, isn't it? Does it sound at all like the pump is running too long? If some of the locks are working normally, then at least the sytem is generally working, so now it's a case of checking individual bits. One thing is the actuators have a rubber diaphragm, which gets brittle, cracks, leaks- result. no movement. Pipes bent. But if everything has been working, then I'd think about the actuators.
I wish they would keep the damned Chinese away now that I can go home, so that I can enjoy Fish amok and a draught Angkor Last edited by Hanuman; 17-08-13 at 01:10 PM. |
Sound like a leaky locking solenoid if the pump is running too long.
80 quattro 20vt Octavia VRS (the daily) '88 Mini turbo (will see the road again.....one day) |
Peugeot or Renault should take that up as there new slogan.
