Members: 43,028 | Total Threads: 40,083 | Total Posts: 471,017 Currently Active Users: 1322 (0 members and 1322 guests) Welcome to our newest member, Esmeraldossyc |
#11 | |
#12 |
I'd forget using rubber, besides which, how are you going to join them at each end of the system? There are plastic ones available made for the job with all the right fittings too, can't remember the name of the product, but mrpat on here has used them on his 80 quattro and they look superb.
#13 | |
What's the reason why you don't want to fit proper copper lines? Are they too cheap or too durable for you? |
#14 | |
#15 | |
If i could find a new set of copper lines, i would use them. As it is i dont have the time or space at the moment to bend and make up my own set from scratch, hence why I'm looking to use the next best thing i.e. plastic braided purpose made fuel line. If you dont have anything useful to say, please refrain from saying anything. |
#16 | |
I'll find out about the plastic lines for you. |
#17 |
I'm sure MSH's intentions are to give the best advice, and I have to agree with that advice replacing the pipes with 5/16ths internal bore cupranickel is the way to go. I've seen an attempt to do it in plastic and the car ended up coming to the workshop to be put right.
With a ramp and the right equipment (flaring kit) its generally 4-5 hours to remove the old system and make up/bend/flare and fit a new set. But dropping the front sub-frame helps as does removing the O/S gearbox mount. Its not an easy job if you are working on the garage floor. IMO you'ld be best to patch the leaking pipe in rubber for now and get the job done properly when either you have the time and equipment available or get it done professionally and then you can forget it.
Roger Galvin Chairman & Technical Secretary, qOC quattro Workshop |
#18 | |
click on offending Username view public profile user lists add to ignore list ![]()
#19 | |
![]() Otherwise I agree to Roger on all points, apart from the need of flare kit - I bought my lines in Hansaflex hydraulic parts store and they did that on one end of each line for additional fee. Actually it wouldn't be even 4-5 hours, if doing quickly, and RHD UR probably is even easier to bend the lines in place, as the biggest problem for me was the place below battery tray, where, obviously, in RHD cars is brake master cylinder located. Garage with pit and one friend in it recommended. |
