Classic Audi » Technical » Technical Info » Power steering fluid g002000
Prev Previous Post   Next Post Next
Old 05-08-13, 06:17 AM   #3
Originally Posted by Error404 View Post
Best bet is just go to the dealer and buy some genuine fluid, its not expensive and they carry it on the shelf.
The only other compatible fluid I know of is the Febi equivalent that GSF sell.
If you're not sure how old or what the fluid is in the system already, I recommend a full drain and flush. the wrong fluid is the most common cause of leaks and failure in the Audi hydraulic systems - you will be surprised how much ugly looking shit comes out
Fully agree about genuine stuff. Easiest thing to buy as volkswagen dealership should be in any town. Also agree about wrong fluid - someone has filled red synthetic oil in my PAS system in the past - well, it works, but some time ago when I was repairing something in winter @ -15c, after starting and instant maneuvering [I had to drive car out of the garage, turn around and drive in garage other way - all that without anything in cooling system] found out a little bit of PAS fluid on engine block. Sometime in future I'll change to green finally.
