Members: 43,034 | Total Threads: 40,085 | Total Posts: 471,031 Currently Active Users: 720 (2 members and 718 guests) Welcome to our newest member, Donverua |
Due to the front strut housing on my type 85 having been mullered by the company that did its air ride conversion I need a replacement pair. Obviously (or not) I don't need/want the damper inserts, springs, brakes, hubs etc.. but I'm flexible id someone has complete front struts and doesn't want the hassle of dismantling them.
Effectively I just need the black metal strut tube/hub carrier.. Anyone help? especially in the south.. |
I have a pair of front struts from an 84 GT5E ........ I'm in west berkshire if they will be any good for you
Where abouts in West Berkshire?
Fit a pair from the first batch of the later series 3 80's. Same strut legs but with wider/larger caliper mounting bolts so big brakes can be easily fitted as I did on mine. Can find part numbers if your interested. Steve Cresswell of C&R told me about these and it meant I could fit the 280mm discs from a G60 Corrado (with slight alteration for the PCD difference) and that looks factory installed. Have the article on it somewhere if interested. Send PM.
When you say series 3 80's do you mean type 89's?
If so does that mean early type 89's had one piece struts, laters going to seperate struts and hub carriers..? |
893 412 025d ???
About 3 miles north of junction 14 M4
Thats about it if you want to be exact its 2 miles
I have an E reg series 3 80 (type 89) that has one piece front struts . Not sure wot year they changed to seperate struts and huds. I did break a G reg (type 89) and that had seperate struts. Hope this info helps
| Type 81 / 85 Front strut bar | Cornholio | General Chat | 2 | 24-01-10 09:52 PM |
| front strut brace for the CQ | Gaz | Parts Wanted | 6 | 27-09-09 09:30 AM |
| wanted type 85 fuse box and "front" loom | newt | Parts Wanted | 2 | 19-05-09 09:12 PM |
| Front foglights - Type 85 Coupe GT | Save Ferris | Parts Wanted | 3 | 07-05-09 10:49 PM |
| Audi Coupe front indicator lens early type | mikes2 | Parts For Sale | 4 | 23-02-09 07:08 PM |
