Classic Audi » Classifieds section » Parts Wanted » Found a FUBA antenna
Old 09-12-08, 11:58 PM   #1
Default Found a FUBA antenna
Hey out there, I had the good fortune to find a really decent antenna for my Coupe.
I'm looking into rebuilding the snapped off unit I had, aside from finding a replacement mast only, has anyone out there tried to retrofit a Fuba amplified antenna? Does any one have a part number for the mast replacement? Are they unobtainium as well?
Old 10-12-08, 08:22 AM   #2
I take it this is the pull up one and not the electric one.
Old 10-12-08, 11:24 AM   #3
Amanda, hey there. Yes this is the pull up one. There was powered retractable one for sale last week on Ebay UK but the starting bid was 199 pounds The motor/wheel section of which seems to screw right onto the simpler version, but this is based on pictues alone. See attached. Thanks.
Old 16-12-08, 01:39 AM   #4
Probably common Knowledge, but if you remove the 4 screws holding the body of a Fuba antenna together, its just a tease. You'd think it should slide apart into 2 sections. Not so much. The interior space which houses the delicate powered electrical connect to the aerial is filled with some kind of hardened insulating foam. Absolutely cannot be pulled apart without ruining the interior. Maybe, with the correct solvent....
Old 17-12-08, 08:12 PM   #5
ChrisG
ChrisG's Avatar
My 80 Sport still has the manual version ( left hand picture)
Were there any takers at £199 ?
The model aircraft guys may have the correct solvent as some of them make fibreglass bits using foam as the mold and then dissolve the foam out with the correct 'stuff' . Trouble is you do not want to dissolve the insulation etc on components..........
Old 17-12-08, 08:21 PM   #6
Both those are now nla and the manual one was standard for cq's and gt's .....the electric one was for the urq but both are interchangeable As far as I am aware the masts for only the urq one are still available from audi.
Old 17-12-08, 09:14 PM   #7
Good to know. Thanks Amanda.
Old 18-12-08, 03:41 PM   #8
ChrisG
ChrisG's Avatar
Amanda, does that mean that although the main ariel part looks the same the mast is actually different....... never had an electric ariel so have no idea about their innards and how the work....
Old 26-12-08, 04:02 PM   #9
Santa (my brother the Audi Mechanic) was good to me for Christmas. He managed to conjure from some gnomes in Zurich, a NOS (new old stock) replacement antenna mast for my Fuba antenna. So now I even have a perfect spare.
I think he sold his soul at some point.
Old 26-12-08, 07:26 PM   #10
ChrisG
ChrisG's Avatar
So ... would there be any more left in the bottom of the sack?
Fuba Electric Antenna Cornholio Parts For Sale 21 01-09-17 11:03 AM
Fuba Electric Antenna Cornholio Parts For Sale 0 05-01-10 04:37 PM
Fuba electric antenna Cornholio Parts For Sale 3 06-08-09 03:14 PM
Did someone want a Fuba arial? Emjay Parts For Sale 6 28-12-08 10:10 AM
Electric antenna Ringmaster In-Car entertainment 4 20-05-08 10:52 AM
