Classic Audi » Technical » Mech/Tech » Suspension & Brakes » what are the biggest 4 stud brakes
Old 19-06-10, 08:46 PM   #11
sam
mk1 focus rs 4x108 and 324mm by 28mm. biggest i know of in 4x108
Old 23-06-10, 07:36 PM   #12
16v80
16v80's Avatar
What about the 4 stud Seat ibiza cupra discs
305mm, 4x100 with the 57.1 centre, redrill to 4x108?
16v80 is offline   Reply With Quote
Old 25-06-10, 12:58 PM   #13
Addicted
They're actually 63mm centre, where the Audi is 68ish.. plus the offset is wrong
I've gone for 2.6 V6 280mm x 22mm discs with Wilwood 4 pots..
1985 Type 81 2 door 2.8 V6
1983 Golf GTI track weapon
1977 Scirocco G60
1968 Sand Rail
Old 25-06-10, 01:00 PM   #14
20vcqdriver
20vcqdriver's Avatar
Be interested in full details of this install, as need some better calipers but something that allows me to retain the 15" Ronal R8
Old 25-06-10, 01:32 PM   #15
Indeed... Escort Cosworth too.
Old 25-06-10, 03:25 PM   #16
Addicted
Easy peasy in reality. I've used 1992 Audi 2.6 discs with Wilwood Dynalites and mounts from Chris Eyre. (intended for mk2 Golfs, but fits our Audi's too)
Part #'s
Discs 8A0 615 301 E
Calipers Wilwood 120-5093
Chris Eyre is a motorsport legend over on Club GTI.
New brake lines will be needed as Wilwood use 1/8 NPT fitting, but when I ordered the calipers from Rally Design they knew the fittings I needed and supplied them.
If you have the earlier front uprights you can use modified G60 Corrado discs which are the same size but with lower offset and the same calipers. Chris does mounts for the mk1 golf if you have caliper carriers with early 75mm centres.
1977 Scirocco G60
1968 Sand Rail
Old 16-07-10, 09:33 PM   #17
Kit
Kit's Avatar
Is it not possible to change the hubs/brake system over from a mk2 golf to suit your purpose?
I know it's not 4 stud but I was hoping to swap the hubs and brakes from a mk3 16v?
Kit is offline   Reply With Quote
Old 19-07-10, 07:24 AM   #18
Addicted
The hubs are quite different I afraid.. certain golf brake calipers can be swapped over though..
1977 Scirocco G60
1968 Sand Rail
Old 19-07-10, 08:54 PM   #19
Kit
Kit's Avatar
what's my best bet front and back while keeping it 4x100 and fitting under 15" wheels?
Old 19-07-10, 09:25 PM   #20
sam
fronts, golf g60 discs and calipers
rears, standard but new
