Classic Audi » Technical » Mech/Tech » Engine » 1990 Audi 100 2.3 NF - 2500 rpm idle!
Old 12-06-08, 12:33 PM   #11
OK, the one off the 100 turbo didn't fit!!! Different plug.
I might just order one off ebay and try that.
Steve
Old 17-06-08, 08:09 PM   #12
Got a new ISV.
No change....
Bugger.
I will try cleaning out the throttle body again (but not tonight......)
Any other ideas?
Old 17-06-08, 08:59 PM   #13
Darn if i was closer id come get my hands dirty....
Old 17-06-08, 09:11 PM   #14
just been on phone to 'Manda, I'm going to replace all of the little vacuum hoses, the fabric covered ones. I might have cracked a previously perished one when I removed them.
Old 18-06-08, 08:03 AM   #15
Octanejunkie
Octanejunkie's Avatar
Easily done.
Had to replace a load of perished ones on my sport. Sometimes they bake hard and crack and sometimes they go all squidgy and collapse...
Make sure that ones that have lots of sucking going on through them are made of good quality stuff or they could collapse under load
Gonna replace all my hoses soon with silicon stuff. Highly resistant to all manner of under bonnet nastiness and they come in pretty colours too.
Old 18-06-08, 08:12 AM   #16
Octanejunkie
Is the distributor in good condition? Do the advance mechanisms work as they should?
Does this engine have an auxillery air valve? It could be broke, letting in too much air.
The problem you're having is almost certainly too much air getting into the system and leaning it out at tickover/low revs.
Are the plugs still a nice browny colour?
Check all the cars "air" related devices.
Does this car have an ECU?
I might be able to pop over Monday or Tuesday if you're about during the day?
Old 18-06-08, 02:43 PM   #17
Dizzy is fine (car was working fine apart from broken fuel pipe, until I took the frigging thing apart!)
It does have an ECU of sorts, being KE-JET rather than K-JET. The Aux air valve has been replaced by the ISV.
I am currently of the opinion that it is getting the correct 14:1 mixture when ticking over at 2400rpm, as it is neither leaning out, or running rich. I think that even though I checked the throttle butterflies, cleaning them out PROPERLY won't hurt.
Because it runs fine (apart from being at 2400rpm), I don't think that there is an air leak in the system, or an overfueling problem.
Easily done.
Bought some 3.2mm fuel hose from Camberley Auto factors today. Will change hoses later.
I *MAY* be about on Monday / Tuesday if my wife has this bloody baby! SPent the morning in Bath Hospital cos she was having 3 minute contractions, lasting 1 minute.
But when we got there, they said, "yes you're having contractions, but go home until something else happens". WTF else can happen? C section booked in 2 weeks but it is torture as she has been contracting for 8 bloody days now and is knackered, but they woldn't do C section today cos they're too busy.
Old 18-06-08, 09:01 PM   #18
cleaned throttle body, made bugger all difference.
My latest theory is......
Engine is NF
New fuel pipes are off an NG (80/90 car) and are shorter. The pipes are a bit "stretched" but I managed to get the injectors to seat into the inserts, and the other end onto the metering head.
The injectors are held in place by a rail. However, as the pipes are a bit "stretched", some of them may be pulled over to a slight angle, and may be letting air in there.
I know everyone has said that already, but I tried squirting WD40 around the injectors, but the manifold is in the way. I also thought that an air leak would manifest itself as lean running, and wouldn't idle very well.
HOWEVER, this car has KE-JET which has a lambda sensor which can correct an imbalance in mixture.
So if it were leaking air in, the lambda sensor would sense lean running and tell the injection system to chuck more fuel in.
My other revelation will be to squirt carb cleaner directly onto the injectors one by one, as carb cleaner sprays a jet of liquid, whereas before I was using WD40 in a mist form, or a blowlamp, and neither are very directional.
That's my thoughts on the matter.
Anybody agree or disagree on my theory?
Only thing is if I find ot the pipes are too short, I'll either have to find some off an NF engine (bloody impossible), or get some made up by goodridge supplier (merlin motorsport at Castle Combe, 10 miles from me).
More bloody cost!!!!!!
Steve
Old 19-06-08, 07:54 AM   #19
I usually use carb cleaner or better still, brake spray as it dosent damage plastics and evaporates nice and quickly.
Old 19-06-08, 09:04 AM   #20
Octanejunkie
I once had a 89 BMW 535i with an erratic idle. Sometimes lumpy, sometimes fast, and sometimes it would stall.
I chased all over the engine bay looking for the fault, replacing more or less every fuel/air related ancillery to no avail.
Turned out it was the ECU. Got another from a scrap yard and it still wasn't right. In the end i bought a used one from Ebay and it sorted it out.
15-20 years in hostile conditions can play havoc with old electrics.
Don't like the sound of those fuel lines though, can't be doing the system any good. Have you had a quote for a set to be made up?
Daft question, but i suppose GSF/Euro parts etc don't have them?
If you're certain your systems are in good order, then the next logical step would be the ECU.
If you can't find another one, carefully, and i do mean carefully, take the old ones case apart and you should find an old fashioned curcuit board inside. Get a magnifying glass or some other magnifying device and check carefully over the board checking for dry joints, corrosion, signs of burning or broken tracks. Take your time about this as it can be tricky to spot. Anything that looks suspect, waft a soldering iron over it and maybe chuck a bit more solder into the joint. If you can, try and have some flux on hand to help the solder flow properly as old solder can be a bit stubborn.
This may all sound a bit extreme, but if you can't get another ECU then repair is the next best thing. I've managed to repair a couple of ECU's in this manner plus a few instrument binnacles too, so its worth a try.
Alternativly, there are companys who will test and/or repair your ECU for you. Last time i looked it was around £100 odd.
1990 Audi V8 3.6 32v 71k Coxy Cars For Sale 23 22-12-09 08:25 AM
1990 Audi 90 SE Couperman Cars For Sale 8 07-12-09 05:03 PM
Audi 80 tdi juddering/ erratic idle kully Engine 1 28-12-08 10:01 AM
Audi 100 2.2 turbo - high idle, then non starting pimpdriver Engine 5 22-11-08 02:00 PM
1990 Audi 100 Turbo snorky Cars For Sale 10 10-04-08 08:05 PM
