Classic Audi » Technical » Mech/Tech » Engine » 1.8t in 5 pot quattro
Old 28-01-10, 09:41 PM   #11
steveb
steveb's Avatar
I got this answer on audifans
http://www.audifans.net/modules.php?...wtopic&t=30979
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 28-01-10, 09:54 PM   #12
stoop44rio
going by our buddies over in motorgeek land you CANNOT bolt a 4 cyl to the 016 box properly,although they do say theres a european version with the 4 bolt pattern(poss mean rare in the usa?). a 4 cyl needs a 01a or 01e they say
stoop44rio is offline   Reply With Quote
Old 28-01-10, 11:25 PM   #13
sam
i've sucessfully bolted a ng 5 pot in a b3 16v quattros gearbox. a 10v turbo onto a b4 16v quattro gearbox and the latest conversion a 1.8t onto a b3 90 quattro gearbox nothing needed other than bolts lol
Old 28-01-10, 11:45 PM   #14
Andy10v
Andy10v's Avatar
There is a few 5 pot-1.8t swaps on motorgeek, as far as I can remember 01a boxes will bolt up to 4/5 cylinders, 01e boxes will also bolt up to both, ie b3/b4 series 3 coupes. 016 boxes are either 4 or 5 cylinder specific.
Think sam has proved that you can swap engines around on the 01a!
2005 350z GT
Sold-1993 ABY coupe
Old 28-01-10, 11:49 PM   #15
Andy10v
Andy10v's Avatar
modern quattro is actually haldex and different layout
WTF? Quattros with transverse engines are haldex.
2005 350z GT
Sold-1993 ABY coupe
Old 29-01-10, 01:54 AM   #16
Gaz
Gaz's Avatar
Thumbs up
Originally Posted by BW2309 View Post
Only the transverse mounted 'boxes are Haldex (that's the rear diff), the longitudibnal ones still use mechnaical Torsen system. A quattro box from an A4 quattro (5 or 6speed available) would be a good plan as only mod req'd would be possible minor fiddling with the mounts.
May need to check on compatibilty of gear ratios with existing rear diff but that's not too dificult to check.
Should make a nice car, the 1.8T is a very tunebale engine and very light.
I ADORE the 5-pots but the 1.8T would make a very good sensible choice for a rapid 80! SHorter, lighter and more powerful.... Keep us updated!
I wouldn't want to give up 'my' 5 pot heaven, but I still would love to see a type-85 Coupe quattro with a 1.8T and 300bhp.
I'd love to see how it goes, & handles.
Old 08-04-10, 08:48 AM   #17
sam
it definately fits
Old 08-04-10, 09:00 PM   #18
J4MES
Sam, that is awesome (if the photo quality is a bit poop). Finally got the MOT on mine so I will be driving it about while I gather up the rest of what I need for the conversion.
J4MES is offline   Reply With Quote
Old 22-04-10, 07:34 PM   #19
jds
Is there a definative answer on this? Some say yes some say no!
Thinking of 5 cylinder type 89 coupe quattro. And then fitting a 4 cylinder 20 vavle turbo in it
jds is offline   Reply With Quote
Old 07-09-10, 08:53 PM   #20
sam
just noticed this post, 4 cylinder 20v turbo definately DOES FIT on type 89 cq gearbox
