Classic Audi » Technical » Mech/Tech » Electrical problems » kv fuel pump wiring?
Old 21-11-09, 04:48 PM   #1
stoop44rio
Default kv fuel pump wiring?
fitting a new fuel pump and theres two wires; brown and green/yellow- which goes where on the new pump? the two connections are different sizes on the new pump and both are marked with +/- , also the old wiring needs trimmed and new connecters fixed. so does the brown go to the bigger terminal or vice versa
stoop44rio is offline   Reply With Quote
Old 21-11-09, 04:54 PM   #2
just get a test light and see whitch one goes live with the ign on
Old 21-11-09, 05:09 PM   #3
stoop44rio
no battery at the moment!
Old 21-11-09, 05:14 PM   #4
did you notice whitch way round when you took it off ?
Old 21-11-09, 05:21 PM   #5
stoop44rio
old pump has different connections and they weren't marked+/-. new pump comes with new terminals so the old wiring has to be cut back and new ends crimped on. aren't brown wires usually earth on cars??
Old 21-11-09, 05:24 PM   #6
carn't you get a batt and just turn on the ign you dont have to start it
Old 21-11-09, 05:30 PM   #7
stoop44rio
prob will have to do that, just thought someone might know abit more than myself!! which wouldnt be that hard
Old 21-11-09, 05:35 PM   #8
Wire colors are of existing wiring harness? If so then brown is ground, as always and that other is +12v. If u will connect them wrong, then pump will only pump on wrong way and engine will not work
Old 21-11-09, 05:46 PM   #9
As MSH suggests, brown is ground ( - ) .
Old 22-11-09, 05:52 PM   #10
stoop44rio
brown being earth would go to the smaller terminal and positive to the sligthly larger terminal?
fuel pump gone ! andy Engine 11 05-11-09 08:47 PM
fuel pump? pimpdriver Engine 6 20-09-09 07:39 PM
Fuel Pump poopcoupe Technical Info 4 04-08-09 04:21 PM
fuel pump Micky Parts For Sale 0 21-09-08 03:54 PM
