Classic Audi » Technical » Mech/Tech » Engine » nasty misfire
Old 16-09-09, 02:45 PM   #61
andy
andy's Avatar
i pulled some kind of sensor out of the top of the inlet manifold, a round one held in with 2 allen bolts. it's a green dash actulaay, is there any kind of fault codes on this or like old astras when you connect some rubbish with a paper clip then read the flashes on a light? seemed like it was only happening in 2nd when i last tried it, strange i thought!
Old 20-09-09, 07:37 PM   #62
andy
andy's Avatar
sorted all thw wires behind the glove, thought it was fine, but today...its back :-(.
drove fine but stuttered a little at 4000 then climbed to around 5000 and stuttered again ...any ideas?
cheers,
Andy
Old 20-09-09, 08:08 PM   #63
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
This 4000 rpm bit still leans toward the air inlet temp sender, but i'd be interested to know what the boost level is when it happens. If the ecu see's too much it will cut the fuel pump, but, tbh when this happens you think the engine has fallen out, not just a misfire !
http://www.oesems.co.uk/
Old 21-09-09, 10:37 AM   #64
andy
andy's Avatar
Ha ha! doesn't seem that bad!
was thinking that maybe the air temp sender could be buggered, or is this unlikely?
cheers,
Andy
Old 21-09-09, 11:01 AM   #65
have you changed your fuel filter? Read my thread on my antics over the weekend!!!
Old 21-09-09, 11:37 AM   #66
quattro-coupe
what colour were the wires behind the glovebox? mine did a similar thing where the fuel pressure regulator on the block was fecked. this over fuelled the engine and made it misfire. try that.
quattro-coupe is offline   Reply With Quote
Old 21-09-09, 03:02 PM   #67
andy
andy's Avatar
I'll try that one, the wires were all kinds, think theres a pic further up.
cheers
Old 21-09-09, 03:03 PM   #68
andy
andy's Avatar
niceone... I'll have to find it now and have a read
Old 21-09-09, 03:05 PM   #69
click here:
http://www.classic-audi.co.uk/forum/...ead.php?t=6650
Old 26-09-09, 11:48 AM   #70
andy
andy's Avatar
think maybe i solved it but havent tested it yet as theres no wheels on her 2day but.... as ashamed as i am to say it.....i think it was just a buggered battery connection....oops. will update later on once its been for a run though
88 wr misfire :-(!! andy Engine 2 30-11-09 06:28 PM
EKKKKKKKKKKKK Nasty, nasty 80 amanda General Chat 11 26-04-09 07:56 AM
Nasty...one lucky sod. Booty General Chat 15 02-10-08 09:13 PM
Anyone got or had a misfire on K jet engine? Octanejunkie Engine 21 15-05-08 10:25 PM
