Classic Audi » Community » General Chat » water ingress
Old 09-05-09, 05:43 PM   #1
Default water ingress
Archie has pissed himself again!!
Thought it was sorted but in heavy rain fall I am getting water into the boot resess on the right side and a rather concernable amount of water under the drivers seat in the rear and front footwells and a bit on the passenger side footwell.
suspect its the sunroof drain but cant be sure, there is no water on the inside of any windows.
Suggestions please...
NO the windows wasnt left open
SHORT of taking the front seats and carpet section out and sitting under a hose, any ideas please?
Old 09-05-09, 06:12 PM   #2
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
Membranes in tact behind the door cards ?
http://www.oesems.co.uk/
Old 09-05-09, 06:39 PM   #3
no idea
how do i check that
if the door is properly closed then wouldnt the door seal keep out water? it doesnt get wet when i wash the sills and spray water under the door to rinse..... not that I have checked mind you. Asuumed it was dry and sorted out when the sunroof drain was cleared out.
if the membrane had failed....would it allow about half an inch of water in? if the door membrane was leaking.... how the hell does it get into the boot?
Old 09-05-09, 06:43 PM   #4
Would the water in the boot be coming from one of the rear light clusters?
Old 09-05-09, 06:50 PM   #5
the rear light clusters should have proper audi mastic around ( chat to amanda ) and as you have had archie painted tenner says its not been replaced with the pukka stuff, if the door membranes are missing water actually gets in viaa the weatherstrip and piddles through the inner door , take the door card off to check rich
Old 09-05-09, 07:06 PM   #6
nice one fellas... Coxy there was a slight trace of water coming from the driver side light cluster, there was about 5mm of water in the resess.... but isnt this quiet a lot considering the gap between the cluster and the body?
Amanda's suggestion that Helen shuts me in the boot with a torch wasnt such a bad idea after all I had better show H were the boot latch is first
What kind of sealant can I use fopr the lights? would a bath silicone sealant do?
membranes will tackle that tomorrow.
Thanks guys great heads up
Old 09-05-09, 07:15 PM   #7
vag80
vag80's Avatar
don't use bath silicone you can buy proper sealer from any vag dealer it comes on a roll in abox i work
for a Seat dealer and we use that stuff on the metal membranes,i can get you part number and price on monday if you like
200k club member
87-b3 80
83-4000 2 door
Old 09-05-09, 07:22 PM   #8
please do, thanks
So if its on a roll how is it appplied, run it around the body edge then attach the light assembly and secure squeazing the seal into place?
this is great news since this has been bugging the hell out of me!!!!!
much appreciated folks
more worried now about the membranes, what if its split, can i still get them or is it the dreaded NLA situation?
Old 09-05-09, 07:26 PM   #9
vag80
vag80's Avatar
no prob give you info monday evening
200k club member
87-b3 80
83-4000 2 door
Old 09-05-09, 07:27 PM   #10
Its a bit like blu tack and you lay it around the seating area for the light, making sure its continuous so no gaps then fit the light cluster and carefully bolt it down to seal it.
Dont go mad or youll crack the light or break the bolts.
Water Mess! ian20v General Chat 6 19-11-09 10:49 PM
Water Splash Isimmo General Chat 2 14-10-09 12:27 PM
Turps vs Holy Water! Coxy General Chat 1 11-05-09 07:55 PM
Water in Coupe GT ZermattGT Bodywork, glass & exterior fitments 16 01-05-09 09:07 PM
Water ingress on 80 Avant Audiden Bodywork, glass & exterior fitments 0 27-03-09 08:58 PM
