Classic Audi » Technical » Mech/Tech » Engine » Won't start when hot - classic Audi!
Old 27-01-08, 06:09 PM   #1
randall977
Mr Typ 43!
randall977's Avatar
Question Won't start when hot - classic Audi!
This is a classic Audi problem. My 200 5E starts fine apart from for half an hour after its warmed up. It refuses to start and then suddenly when the temp drops to a certain level is fine again. My two suspects are the warm up regulator and the auxillary air valve - both have bi-metallic strips. I also have a slight problem where the revs go up instead of down when the engine warms up - I suspect the two things are related. What should I replace first - the fuel enrichment device or the air enrichment device? or could it be something else... (btw it's not the CSV).
Old 27-01-08, 06:24 PM   #2
crisarc
Default hot start,
I had the same prob on my 200q, eventually changed the injectors[last] symptoms improved , they are as i am sure you know notorius for poor hot start , you could also check the injector fan switch,,this blows cold air on to the injectors, lastly and most expensive ,weak fuel pump , relatively easy to check[in line guage should do it] although the pumps i had probs with were all fairly noisey as they got more tired, best of luck, liked
the resto pics
chris
Old 27-01-08, 07:21 PM   #3
randall977
Mr Typ 43!
randall977's Avatar
Thanks for the advice. The injectors are new and so is the pump -a weak pump is a possibility as the pump was not genuine??? The air valve is okay I think and I can't see that the warm up regulator would stop it starting all together. What about the thermotime switch??? Thanks, I know this is a boring subject!
Old 28-01-08, 09:48 PM   #4
randall977
Mr Typ 43!
randall977's Avatar
Default Thermotime switch
I have found the problem - the thermotime switch is only delivering 4.5V. Anyone know if I can get a replacement from Audi? Would this cause a problem with warm starting?
1995 Audi Coupe wont cold start!!!!!!!! aheath55499 Engine 2 08-10-09 09:35 PM
Audi 100 Typ 44 jump start terminals? pimpdriver Electrical problems 10 11-02-09 08:28 PM
why won't it start? aeinstein Engine 4 28-01-09 10:05 PM
audi 90 poor cold start...... johnboy Engine 14 25-09-08 05:43 PM
