Classic Audi » Technical » Mech/Tech » Engine » Head gasket failure or something worse??
Old 30-04-13, 08:46 PM   #1
andydunn2
Ragtop Collector
Default Head gasket failure or something worse??
Ok I think one of the head gaskets has failed on my 2.8 cabbie (using water and mayonnaise in the filler cap).
BUT I'm also getting low oil pressure 0.5bar when hot and oil warning light, is this connected to the head gasket or is something more serious going on
"Earl" 1998 2.8 V6 Cabriolet
Old 30-04-13, 09:26 PM   #2
missfire
missfire's Avatar
Head gasket's pretty serious isn't it!. i doooo hope you are not driving it?
Old 30-04-13, 09:36 PM   #3
andydunn2
Ragtop Collector
Head gaskets I can deal with, if its bores, rings etc i am getting out of my league don't want to change the head gaskets and still find I have low oil pressure.
No she is a driveway queen at moment while i get the other jobs done to her...
Old 30-04-13, 09:39 PM   #4
missfire
missfire's Avatar
It'll lose oil pressure through the gasket though, won't it?
Old 01-05-13, 01:09 PM   #5
TeXerv
TeXerv's Avatar
Normally the head gasket gets burned between the pot bores and / or the coolant bores. Sometimes the oil return is leaking at the gasket. But I'm not sure whether the pressure circuit might fail at the head gasket. So you should have visible oil leaks, excessive oil consumption, or a clearly recognizable coolant / oil blend.
Old 01-05-13, 09:01 PM   #6
andydunn2
Ragtop Collector
Not sure as almost all other head gasket failures I have had over the years has been a catastrophic cloud of white smoke rather than what I have on this which is some coolant loss mayonnaise on the filler cap and low oil pressure.. .
Old 01-05-13, 09:04 PM   #7
andydunn2
Ragtop Collector
The only oil/water mix I am seeing is mayonnaise on the oil filler cap. No obvious external leaks that I can see...
Old 01-05-13, 09:27 PM   #8
TeXerv
TeXerv's Avatar
Mayonnaise might also appear under cold and wet weather conditions when the vehicle is mainly operated on short trips. So the engine doesn't reach it's serious operating temperature.
Due, oil might be thinned with condensates, causing declining oil pressure.
I would change oil an filter first.
Old 01-05-13, 09:32 PM   #9
andydunn2
Ragtop Collector
Yes my brother suggested that as well, car has been off the road for around 2 years prior to me buying it so oil could easily be goosed.
Will give it an oil change at the weekend and see what happens...
Old 02-05-13, 12:22 AM   #10
fj1200
Going back to my days at the dealer now. We did MANY head gaskets on 12V v6 engines, was always oil leakage. Usually they leaked when piping hot at RPM. The place to look is in the valley between cylinders 4 and 5 (front two of your passenger side). Get it good and hot, clean aggressively and hold engine at 3K revs. Watch for oil forming at head to gasket joint.
The other common failure is the oil cooler, check the overflow bottle for oil residue. Due to differential pressures the two fluids go either way (kinky, no?). When the engine is running the oil pressure is higher so oil migrates to the coolant. After shutdown the cooling system pressure is higher so coolant migrates into the oil.
Hope this helps, Cheers.
Dan
fj1200 is offline   Reply With Quote
