Head gasket failure or something worse??
Ok I think one of the head gaskets has failed on my 2.8 cabbie (using water and mayonnaise in the filler cap).
BUT I'm also getting low oil pressure 0.5bar when hot and oil warning light, is this connected to the head gasket or is something more serious going on :wall: |
Head gasket's pretty serious isn't it!.:lol: i doooo hope you are not driving it?
No she is a driveway queen at moment while i get the other jobs done to her... |
It'll lose oil pressure through the gasket though, won't it?
Normally the head gasket gets burned between the pot bores and / or the coolant bores. Sometimes the oil return is leaking at the gasket. But I'm not sure whether the pressure circuit might fail at the head gasket. So you should have visible oil leaks, excessive oil consumption, or a clearly recognizable coolant / oil blend.
Due, oil might be thinned with condensates, causing declining oil pressure. I would change oil an filter first. |
Will give it an oil change at the weekend and see what happens...:tup: |
Going back to my days at the dealer now. We did MANY head gaskets on 12V v6 engines, was always oil leakage. Usually they leaked when piping hot at RPM. The place to look is in the valley between cylinders 4 and 5 (front two of your passenger side). Get it good and hot, clean aggressively and hold engine at 3K revs. Watch for oil forming at head to gasket joint.
The other common failure is the oil cooler, check the overflow bottle for oil residue. Due to differential pressures the two fluids go either way (kinky, no?). When the engine is running the oil pressure is higher so oil migrates to the coolant. After shutdown the cooling system pressure is higher so coolant migrates into the oil. Hope this helps, Cheers. Dan |
| All times are GMT. The time now is 03:40 PM. |
