Classic Audi » Technical » Mech/Tech » Engine » fuel pipes rusty
Old 11-12-07, 07:35 PM   #1
Default fuel pipes rusty
The fuel pipes (braided steel ones) from the KE-JET metering head to injectors are well corroded (well the ends are). How important is this, and can I get new ones made up???
Steve
Old 11-12-07, 07:54 PM   #2
My underneath fuel pipes have been replaced by copper and passed an mot Think you can get all the fuel braided ones repaired, you just need a fuel injection specialist .....I do stand to be corrected though if anyone knows better.
Old 12-12-07, 08:25 PM   #3
ChrisG
ChrisG's Avatar
is there a question mark over copper fuel lines then?
Part of the rear of my return pipe went a bit leaky, I just cut it off and replaced the flexible with a piece 18" longer ! I did wonder about Kneifer pipe( spelling? ) but didn't get beyond thinking....... I'm sure that it is stronger than the 'ordinary' copper pipe.
Old 12-12-07, 09:10 PM   #4
randall977
Mr Typ 43!
randall977's Avatar
I replaced all of my solid fuel lines with 8mm copper heating pipe. It is perfect dimensionally and soft to create the flanges at the joints (I also used a sealer available from Frost's). Copper pipe should withstand at least 300psi and Jetronic runs at 75psi. Flexi pipe is fine as far as I know but I went for copper to try and keep it as original as possible - the colour looks nice too!
Old 12-12-07, 09:33 PM   #5
CuNiFer I think.
http://www.cunifer.com/
Old 12-12-07, 09:36 PM   #6
randall977
Mr Typ 43!
randall977's Avatar
Brake pipes are way too small, the proper flanging tools are expensive - I used a £4.99 eBay purchase to do mine...
Old 15-12-07, 07:57 PM   #7
ChrisG
ChrisG's Avatar
Thanks, I'll file this away for the right time !
Old 21-12-07, 12:07 PM   #8
The pipes I need are only available from main stealers at £53.50 EACH + VAT!!!
I'm going to contact Pirtek to see if they can do anything cheaper:
http://www.pirtek.co.uk/pdf/catalogu..._section03.pdf
Will let you know.
Steve
Old 24-12-07, 06:35 AM   #9
Pirtek said the pipes are too small, spoke to a mate who popped round on Friday, he got a fuel pipe for his Aprilia made up at a motorsport place near Castle Combe circuit for a fraction of the main dealer price.
Will try them in the new year.
Audi 100 NF engine KE Jet fuel pipes poss AAR pimpdriver Parts Wanted 2 25-04-15 06:24 PM
sandwich plate & oil pipes foruse with a Mocal oil cooler Gaz Parts Wanted 1 28-01-10 09:11 AM
Fuel lines rusty pimpdriver Engine 5 25-04-09 06:50 PM
Audi 100 NF engine KE Jet fuel pipes pimpdriver Parts Wanted 0 30-03-08 10:46 PM
Audi 100 NF engine KE Jet fuel pipes pimpdriver Parts Wanted 1 29-01-08 11:45 AM
