Classic Audi » Technical » Mech/Tech » Engine » Engine doesn't fire when warm...
Old 16-09-10, 11:00 PM   #1
Daveymaclad
Daveymaclad's Avatar
Default Engine doesn't fire when warm...
I have an unusual problem with my mb quattro.
When firing the car up from cold the alternator turns over a few times then the engine slowly but surely burbles into life. From first start I can happily turn the engine on again for the first 5-10 minutes from cold start no problems.
The problems occur when the cars been running for more than 10 minutes. Once I turn off the car and leave it more than a couple of minutes the car simply won't start back up again. The starter motor is turning but the engine just won't catch/ignite. In this state I can fairly easily bump start it so I'm really confuzzled as to what could possibly be the matter.
As it is it makes fuel stops an absolutely critical event regards timing, either I fill her up within a few minutes of firing from cold or be prepared to bump her off the forecourt!!
Thoughts/suggestions anyone?
2008 RS6 avant
SOLD 1988 UR Quattro
Old 16-09-10, 11:39 PM   #2
missfire
missfire's Avatar
do you hold the accelerator pedal half way down on hot starts.? that helps (only on hot starts)
Old 17-09-10, 07:27 AM   #3
Daveymaclad
Tried no pedal down, pedal half down and pedal full down, all to no avail
Getting quite frustrated with it now as I love driving the car but know that I can only drive it in a circle straight back home where I can park it up before it refuses to start again!
2008 RS6 avant
Old 17-09-10, 07:47 AM   #4
It may be just the very late night, and being up much earlier than I'd like...
But something doesn't quite read right.
Are you saying alternator when you mean starter motor?
Old 17-09-10, 07:51 AM   #5
Daveymaclad
You're bang on, it was late, I did mean starter motor - now changed!! Something to do with getting married today is occupying my time away from the Audi :P
2008 RS6 avant
Old 17-09-10, 08:12 AM   #6
good luck for today!
Shouldn't really be on here then should ya!?!??!?!
Old 17-09-10, 08:14 AM   #7
Phil Payne
Banned
http://www.isham-research.co.uk/quat.../mac12pin.html
Old 17-09-10, 09:47 AM   #8
Daveymaclad
Forgot to mention the Quattro features quite heavily in the wedding, being the vehicle taking me to and us from the venue!!!!
2008 RS6 avant
Old 17-09-10, 10:02 AM   #9
missfire
missfire's Avatar
emergency on planet audi.......!!!!!!!!!
if it bump starts readily then it can only be starter, battery of terminals surely....?!?!?!
give the terminals a clean..? check voltage of battery if you can..?? starter engaging flywheel properly..??
i know there is a mb thing where if the ecu does not like the look of something then it will refuse to start the engine......but if it is bump starting then the ecu must be happy..(?)
Old 17-09-10, 10:12 AM   #10
JimC
JimC's Avatar
... getting married today is occupying my time away from the Audi :P
I hope all goes well for the wedding. CONGRATULATIONS. After 21 years of marriage, I can still recommend it.
JimC is offline   Reply With Quote
