Classic Audi » Technical » Mech/Tech » Engine » hunting idle when cold
Old 03-03-10, 07:56 PM   #11
missfire
missfire's Avatar
Originally Posted by Gouldy View Post
yes it does mate, will try to source one i think as im sure it should cut out if you unplug it?
mine speeds up if you unplug it..................
if it works you should be able to hear it 'buzzing' on first ignition...
mine kind of goes.....'on...off....on...off...on...off'
Old 03-03-10, 08:11 PM   #12
Gouldy
Gouldy's Avatar
ah ,there maybe something there then,
also the fuel pump is very noisey, but it drives fine and makes a noise all the time
Old 03-03-10, 08:29 PM   #13
missfire
missfire's Avatar
my pump makes a fair bit of noise too....am keeping my fingers crossed..but know it will need a change one day..
at least..if they are making noise....we know they are working..!!
mine makes far more noise when the fuel level if low....turns the fuel tank into a big resonator...!
Old 03-03-10, 08:40 PM   #14
Gouldy
Gouldy's Avatar
haha, i havent noticed any change in noise with the tank tbh lol,
will try and have a play with the sensors/switches at the weekend i think, see if i can see anything untoward
Old 04-03-10, 04:32 AM   #15
could it be the throttle body switches on the side? 1 for idle and the other wide open throttle?
or the warm up reg valve?
Old 04-03-10, 06:38 AM   #16
Alfashark
Alfashark's Avatar
I know there's a lot of talk about ISV's going on here but...
My KV had a pig of an idle when I got it, replaced all suspect breather hoses but still had the funky idle
Try this - disconnect the vacuum hose to the brake booster and bung the end up! Solved my problem
Booster diaphragm has a pinhole, so the whole unit will be replaced shortly... Strong legs so braking isn't an issue in the mean time
Alfashark is offline   Reply With Quote
Old 11-11-10, 11:46 AM   #17
Gouldy
Gouldy's Avatar
right guys, just had a text from the guy rebuilding the head and he said its still running lumpy when cold
its had new injector collars and o rings, new headgasket, new plugs, rotor and dizzy seem fine
again when its hot it runs fine but when it first starts up it hunts, i have taken off all the vacuum hoses and they all seem fine, when i unplug the ISV nothing changes, likewise with the Cold start injector
any ideas?? or anyone willing to pop around in the next few weeks and have a gander for me?
Old 02-12-10, 12:10 PM   #18
Gouldy
Gouldy's Avatar
got a bit further on this today , got a circuit tester light on the ISV and the Cold start valve and NONE have live when running or with the ignition on ....
do they run off the same relay?? if so i probably need a new one... checked all fuses and all ok
Old 04-12-10, 11:04 AM   #19
Gouldy
Gouldy's Avatar
does anyone know if i can just run a new live to the ISV?? so that its on whenever the ignition is on, likewise with the warm up reg???
or do they HAVE to run to the ECU etc
not overly worried about the cold start valve/injector as the weather doesnt get THAT cold down here
Old 04-12-10, 12:13 PM   #20
Phil Payne
Yes, the cold start injector is up on the inlet manifold, we run both of ours disconnected all year, they're ideal for very cold starting, but with the uk's temperate climate they can, even when working normally, flood the engine when cold.
Bolleaux.
There's something wrong with your systems - probably they've been set over-rich to start because something in the cold start system is bust. The idea that Audi would ship hundreds of thousands of cars with cold start valves fitted that they don't need is ludicrous. They do hot start tests in Death Valley, for heavens' sake.
I hate to think what your fuel consumption is.
