Classic Audi » Technical » Mech/Tech » Engine » hunting idle when cold
Old 02-03-10, 08:01 PM   #1
Gouldy
Gouldy's Avatar
Default hunting idle when cold
hi guys, my recently acquired, Coupe GT has got a hunting idle when cold
when warm it idles perfectly, and the car drives perfectly when hot and cold
I have check the idle stabiliser for Current going into the unit and there is power going to it, however if i unplug the unit (whilst its hunting) nothing changes.
is this a sign of a nackered idle unit or does this unit only work at certain times
the car is also running quite rich
many thanks
jim
Old 02-03-10, 08:15 PM   #2
many thanks
jim
Hmmm... Try disconnecting the cold start injector....
Old 02-03-10, 08:17 PM   #3
Gouldy
Gouldy's Avatar
i take it this is the one with the green plug on the IM? should i disconnect it when running/hot/cold?
Old 02-03-10, 08:24 PM   #4
Yes, the cold start injector is up on the inlet manifold, we run both of ours disconnected all year, they're ideal for very cold starting, but with the uk's temperate climate they can, even when working normally, flood the engine when cold. If the injector is partially blocked and firing longer than required, it could make the old girl hunt. BUT, it could quite easily be something else.
Old 02-03-10, 08:31 PM   #5
Anyway of over hauling the cold start injector?So expensive,for what they are.
Old 02-03-10, 09:17 PM   #6
Gouldy
Gouldy's Avatar
thanks for your help isimmo, much appreciated, will keep you updated!
Old 03-03-10, 07:23 AM   #7
Gouldy
Gouldy's Avatar
i tried the 6th injector this morning . And no difference i am afraid.
Old 03-03-10, 07:57 AM   #8
Okay-doakes, back to stage one then...
Old 03-03-10, 11:20 AM   #9
Tarka
German Language Assistant
Tarka's Avatar
Does this engine have an idle stablisation valve? Common problem on 1.8 Golf GTI engines. The ISV can get dirty and cause this hunting. ISVs can be cleaned but not too expensive to replace and quite an easy job.
1976 Audi 80 L - Sleeping
1977 Audi 80 GLS - W.I.P
1991 Golf Mk2 VR6 Supercharged
2003 Audi A6 Allroad - Daily
Tarka is offline   Reply With Quote
Old 03-03-10, 06:44 PM   #10
Gouldy
Gouldy's Avatar
yes it does mate, will try to source one i think as im sure it should cut out if you unplug it?
