Classic Audi » Technical » Mech/Tech » Engine » Performance Tuning the 10vT engines..
Old 13-05-08, 11:02 PM   #1
wedgedout
Default Performance Tuning the 10vT engines..
Anyone got any pointers?
I want to make it go quicker
It's the "KG" Engine I'm told.. and fitted with a dynalinx exhaust manifold.
wedgedout is offline   Reply With Quote
Old 14-05-08, 03:52 AM   #2
I will be looking at doing the same in the future (MC engine).
bigger intercooler?
head work?
carry on the decent exhaust path?
different injection system
have a look here:
http://www.edition38.com/forums/inde...howtopic=90803
Steve
Old 14-05-08, 08:50 PM   #3
Alpha
Alpha's Avatar
Try these guys...exchange rate helps...
http://www.034motorsport.com/
Alpha is offline   Reply With Quote
Old 15-05-08, 08:16 AM   #4
4v6
Intercooler upgrade would be useful from the view of keeping the charge dense when you raise the boost level, as doing that is pretty much a guarantee of getting extra power, however youll also have to contend with the inherent design limitations of the k-jet system in respect of how much air it can flow and still give correct fuelling.
Dont want a lean out situation occuring so a standalone management would be advisable.
Headwork, i do that already, pm me if you wish or take a look at this articlehope this is ok with "der management") ?
http://www.audifans.net/modules.php?...=19685&start=0
Exhaust system will likely give a benefit also depending on how restrictive it currently is.
Hope this helps.
Old 15-05-08, 06:01 PM   #5
Tom C
If your going to be making any real power (above 250 bhp) you need efi.
Old 15-05-08, 06:18 PM   #6
Octanejunkie
Octanejunkie's Avatar
Hmmmm... water injection, nitrous oxide maybe? Its pretty dear to tune 5 bangers. You could have the head gas flowed, then re cut the valves with new seals and guides. That alone would perk an old engine up no end and wouldn't be too dear.
Old 15-05-08, 06:52 PM   #7
Tom C
water injection isnt much point unless you have efi (you can run it off a solenoid to the ecu then) and NoS isnt true hp IMO,
Old 15-05-08, 06:55 PM   #8
Octanejunkie
Yes, those first two suggestions were just for a bit of fun.
Old 18-05-08, 07:59 PM   #9
wedgedout
bigger intercooler?
head work?
have a look here:
Steve
Ohhh, nice thread, that one of yours?
Old 18-05-08, 09:01 PM   #10
not my thread unfortunately. That guy knows his stuff. And I think he does it as a business too.
Steve
AV Performance Open Day.. Threadus reserectus! Coxy Gatherings and Events 49 21-02-10 09:52 PM
10vt turbopuika Parts Wanted 2 14-12-09 11:12 AM
20v turbo performance chips for 3B engine code 20vcqdriver Parts For Sale 0 04-08-09 09:48 AM
Just a good dyno on a 10vt:D tommyboy General Chat 0 05-07-09 12:35 PM
