Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Bloody Audi calipers!
Old 07-08-11, 10:24 AM   #21
Audiden
Audiden's Avatar
Originally Posted by Lofty View Post
Just been playing with Moneypits caliper's and the Drivers side handbrake actuator wont return to its stop......thought I had cured it a couple of days ago but it just wont return.....
New calipers time ?
Deff not the cable? Disconnect the cable from the caliper lever & using WD40, try working the lever back & forth. Worked wonders with the one on mine.
Too many cars!!
Old 07-08-11, 10:48 AM   #22
I'm in the same situation as Lofty, thanks for that, I'll give it another go on Monday or Tuesday when I get a spare hour.
Old 07-08-11, 03:18 PM   #23
Lofty
Lofty's Avatar
Thats what I have been trying for the past 2 days....to no avail.....
Old 13-08-11, 06:49 AM   #24
Lofty
Lofty's Avatar
Stripped down the calipers this afternoon and cleaned out all the rust that had climbed up the handbrake actuators, they were a right state inside ......Then what a frickin job to get everything back together.....
Old 13-08-11, 08:18 AM   #25
But did it fix the problem Lofty?
Old 13-08-11, 02:55 PM   #26
Lofty
Lofty's Avatar
Hopefully, Ian !
I literally took the things completely apart.
There was rust about 3/4 of an inch up the actuator arms inside the caliper behind the rubber seal , so cleaned it all out and rebuilt the calipers.
Mrs Lofty refused the funding for new ones so had no choice but to tear 'em apart....not a job I wanna do again in a hurry.....
I had to make my own long nosed circlip pliers from a set of long needle nosed ones to get down into the piston bore and clamping the spring mech to get the circlip back in was frustrating.
The actuators are completely free moving now and snap back on their stops where as previously the slowly meandered back(ish).
I am replacing the rubber flex hoses with steel braided replacements so once that's done and the brakes bled I'll let you know......
Fingers crossed.
Old 13-08-11, 05:54 PM   #27
Audisimon
Audisimon's Avatar
Send a message via MSN to Audisimon
I had the same problem on my A6, it turned out to be the balance bar on the handbrake lever end..... It managed to spin round whilst changing the cables thus havin no effort on one side
Audisimon is offline   Reply With Quote
Old 14-08-11, 03:55 PM   #28
Hopefully, Ian !
Fingers crossed.
Inspired by your lead Lofty, I set too today... Stripped down the rear caliper, cleaned everything I could find, hit a few things with a hammer and put it all back together again...
And...
Hey-presto I can apply and release the parking brake and foot brake and the car will roll again...
Thanks lofty for inspiring me to 'have a go'...
Old 14-08-11, 07:36 PM   #29
Lofty
Lofty's Avatar
I
I'd keep that quiet if I were you....it is likely to ruin your image.......
Old 14-08-11, 07:54 PM   #30
But, but...but, you're originally from Eastbourne and that's cool.... Right?
I assumed if you could do it, there was a sporting chance I could!
