Classic Audi » Technical » Mech/Tech » Engine » 200 quattro turbo help (new member)
Old 27-07-10, 06:54 AM   #11
Phil Payne
Originally Posted by phil200 View Post
Ok I will refit the hose, is it blanked off or open to the elements? Also I'll clean the idle valve later but get a feeling that's not my problem. It runs lumpy until 2000 rpm or so and seems to idle too low. I'll put new plugs and distributor cap on it as they're not great but it wouldn't cause it to be difficult to start when hot?
If it's a KG then http://www.isham-research.co.uk/quattro/wr_hoses.html is reasonably close. Otherwise - is there a reason you're not posting the engine number?
Old 27-07-10, 07:08 AM   #12
phil200
No reason, I don't have the new log book yet and not sure where it is on the car? I know its a KG engine if that helps? If not tell me where to look and i'll post it.
phil200 is offline   Reply With Quote
