Members: 19,817 | Total Threads: 40,093 | Total Posts: 471,108 Currently Active Users: 12976 (2 members and 12974 guests) Welcome to our newest member, Azinodeek |
big gimping
anyone ever fitted p slots to an 80? what wheel bolts did you use? i thought the original 80 ones didnt stick into the hub enough so used the ones i bought for the orange rials, after reversing 3 inch i stopped due to clunking noise from the rear hubs/ can wheel bolts be to long help
poss it's long bolts .jack up the rear only use 1 bolt and undo a bit at a time and see if the clonking goes
it sounds like the bolts are to long and catching on the brake shoes,dose the wheel turn? you can buy the bolts in different
lengths you need to measure how much the original bolts threads stick out of the original wheel hope this helps
big gimping
thatll be a job for tomorrow i was fannying around in the dark as it was,
3 solutions:
#6 | |
![]() put a nut, that fits, all the way on to the stud..... grind the 'fecker'....... as you take the nut off it will open up the threads again..... ![]() its not my tip........an old guy told me.....! |
had the same problem with mine so out the came the angle grinder...POWWWWEEERRR
