Classic Audi » Technical » Mech/Tech » Engine » Rattle from back of rocker?
Old 17-11-08, 05:56 PM   #1
90coupe
90coupe's Avatar
Default Rattle from back of rocker?
Hi, ive got a noise which has developed from inside the rocker cover, and was wondering if anyone can help?
Basically the rotor arm metal contact broke when the engiene was running...i got a new rotor arm and when i started the engiene there was a noticable rattle inside the rocker cover towards the back. The noise only occurs when it gets to about 3000rpm, and then fades out back to idle...it never did it before the rotor arm broke so im assuming it has to be something to do with the distributor?
Any help id appreciate, thanks
90coupe is offline   Reply With Quote
Old 17-11-08, 07:04 PM   #2
4v6
Not part of the broken rotor arm still inside the distributor?
Old 17-11-08, 07:11 PM   #3
Is it a 20v? Only the Distributor Drive Gear and Camshaft Drive Chain are both infamous for rattling.
Old 17-11-08, 10:35 PM   #4
90coupe
90coupe's Avatar
Hey, thanks for the replys, its definatley coming from inside the rocker cover towards the back. But i noticed it stopped for a while whilst i was driving and then it came back again when i started it again in the evening...
hey Isimmo, nah its 10v.; my mate said its proberly the hydraulic tappets....i have noticed theyve got pretty noisy the last week or so. The cars over 100,000 miles now too
Mayby its just a really noisy tappet at the back? sounds really bad when it does it
matt
Old 17-11-08, 10:39 PM   #5
matt
If it's tappets, give it a good engine flush and oil/filter change to a VAG approved oil (Synta Gold or similar)... It 'should' makedly reduce the tappet noise or cure it completely.
Like this... maybe..
http://www.autoadditives.co.uk/wB_sh...ce_action=show
Old 19-11-08, 09:56 AM   #6
joe90
Probably the fith cylinder lifter. Iv'e had 86 000 mile cars do it and 210 000 mile cars that didn't, but the ones that did the noise would come and go, and some sounded like the engine was ready to give in but never had a problem. I was told by a mate who has been buying, selling and running audi's for over 20 years that the fith cylinder lifter doesn't get enough oil, and he also told me audi stripped a high milage engine with this fault to find no damage at all, which in my experiance is probably right as i have "driven em like i stole em" and never had any mechanical faliures at all.
Bryan
Old 19-11-08, 10:57 AM   #7
4v6
Did you know......that you can actually partially strip hydraulic lifters and clean them? At least on 10 valvers anyway.
If you turn them upside down theres a protruding valve that contacts the valve stem.
If you carefully grip this with pliers and lightly twist it as you pull, that valve will come out so you can soak it in paraffin overnight to remove the deposits.
This has been a public service announcement on behalf of the Audi Party.
Old 19-11-08, 02:27 PM   #8
90coupe
90coupe's Avatar
Thanks for the replys, ill give it a oil flush and change, and hopefully be better, thanks
Old 08-04-11, 08:05 AM   #9
Phil Payne
Originally Posted by joe90 View Post
I was told by a mate who has been buying, selling and running audi's for over 20 years that the fith cylinder lifter doesn't get enough oil, ...
Bollocks, not to mince words.
However - you'll notice that the lifters are not quite directly under the cam lobes. Each time the lobe comes down, it imparts a small tangential force to the lifter so that it turns to spread wear uniformly over the upper surface.
Sometimes you get a 'cyclic' lifter - tap taP tAP TAP TAp Tap tap. On a solid lifter engine, this is caused by a piece of detritus under the shim - on a hydraulic lifter car, it's a sign of the lifter starting to fail. When the lifter inlet oil inlet hole is opposite the feed hole in the block, it pumps up and goes quiet. A few seconds later and the inlet hole is 180 degrees away and a failing lifter will collapse a little, giving a tick.
The trick is to listen very carefully and try to discriminate the lifters from one another. The cycle is usually about five seconds, but varies along every engine so you will sometimes hear 'beats' and sometimes just a general racket.
HELP. engine rattle :( ferris360 Engine 5 11-05-09 07:31 PM
clutch related rattle??? Gaz Transmission 10 21-04-09 11:27 PM
rocker box retaining strips Micky Parts Wanted 1 25-01-09 12:15 PM
I'm Back 90Quattro General Chat 7 17-08-08 09:30 PM
