Classic Audi » Technical » Mech/Tech » Engine » 88 wr misfire :-(!!
Old 28-11-09, 01:23 PM   #1
andy
andy's Avatar
Default 88 wr misfire :-(!!
Hi all,
The Wr has developed a misfire at around 2500-3000rpm (when it comes onto the turbo) Missis and really struggles to build. Ive cleaned the air flow metre, checked the fuel rate and looked for a boost leak but no luck. Guess ignition is the next place to look but someone suggested to me, (as the car sometimes struggles to start the fires up 4th or 5th time) That the diaphram ontop of teh airbox is prone to wear. Can anyone confirm this or sugest where i go next??
brighter note, adjustable koni's, new CV and new steering wheels arrived today :-)
Many thanks
Andy
andy is offline   Reply With Quote
Old 28-11-09, 06:33 PM   #2
gabriel.oconnell
gabriel.oconnell's Avatar
if you want i have 2 airbox metering head for the wr if you want them ans many other parts fotr the car
Old 30-11-09, 06:28 PM   #3
steveb
steveb's Avatar
Try the pipe between the manifold and wastegate, is not blocked check the connector in the Exh. manifold as well as this could be blocked
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
nasty misfire andy Engine 69 26-09-09 11:48 AM
Anyone got or had a misfire on K jet engine? Octanejunkie Engine 21 15-05-08 10:25 PM
