Classic Audi » Community » General Chat » bloody rain, Archie's pissed himself AGAIN
Old 02-11-09, 05:10 AM   #1
Default bloody rain, Archie's pissed himself AGAIN
YES he is at it again, as soon as it rains heavily the WR passenger side footwell gets a soaking.
I am REALLY starting to get pissed off with this now, I can only use him 2 days of the year it doesnt rain up here.
No move then jokes thanks
checked around the fusebox, its bone dry, carpet coming down from up under the dash is dry, transmission tunnel carpet is dry, behind the glovebox looks dry as well, the screen is dry inside.
there is what looks like a split between the fusebox and the top of the heater matrix,along the plenum chamber as I would call it where would this lead to?
Also, the black cover isnt exactly in the best of nick either.
on the inside of the wing, there is a hole cut out in the wing so I assume this is for drainage..... surely it couldnt be getting in here could it?
I re-sealed the hole for the bonnet cable release so its not coming in from there.
Anyone got some good ideas please because I am at my whits end having to bail him out when he gets wet.
thanks
Old 02-11-09, 06:45 AM   #2
the big holes in the inner wings are for drainage rich, just keep em clear of leaves. My white one did the same as yours and i tracked it down to the windscreen, it had a new screen and rubber put in and cured it so the screen rubber may have moved or been put in badly on mine...just a thought as i checked the usual bonnet pull routing etc
Old 02-11-09, 09:20 AM   #3
Get inside and have someone spray the car on firts the left side front and then the right side.
Get a good torch to have a look under the dash with and see if you can locate it that way.
Old 02-11-09, 09:25 AM   #4
Move somewhere drier...
Old 02-11-09, 09:25 AM   #5
Did you ever sort out the door membranes?
Old 02-11-09, 11:51 AM   #6
gabriel.oconnell
gabriel.oconnell's Avatar
hi m8 hope you sort it asap ,poor archie if you said i had a spare black cover a new one which one of the audi quattros guys has yet to pay for it yet try door seals too i got a door seal and a fuse box if you want them there yours ok m8
Old 02-11-09, 12:36 PM   #7
thanks Folks.
Gabriel I'll relieve you of the black plastic thing that covers the matrix please.
Screen.... the screen was removed during prior body repairs. It looks well sealed, the door membrane on the drivers door was supposed to have been replaced when they did the door window mec. Apparently the plastic membrane doesnt keep water out.... its part of soundproofing!!!!!
its just the amount of water getting in, when i push my fingers into the carpet it reaches my first knuckle
no leaves, birds nest under my bonnet but I cant see inside the drain hole to see if its been disturbed during body repairs.
Water ingress is a TW*T because it could be anywhere and not where you think it would be coming from
where's my eductor?
Old 02-11-09, 01:09 PM   #8
Have you checked?? I have heard of this being a problem leading to water ingress. I wouldn't take the words of a garage at face value tbh
Old 02-11-09, 01:13 PM   #9
soon find out, thanks Martin
it was parked nose down in the drive if this gives a clue. I wondered if it a sunroof drain issue?
so thats 3 Audi's NEEDING fettling.
1) Archie wants to join the submarine service!!!!
2) RS4 has shreaded a front tyre..... awaiting 2 new to arrive this weekend, because its such a low profile (255/35/18's) its dificult to tell if it needs pumped up, soon found out when I went over a cats eye!!!!!!!! tyre on the inside has been worn down to nearly bald and the wires coming through!
3) cabrio has a warped passenger side front disc and possibly a knackered drop link so thats back at the dealers again!!
Helen is using the Aygo.... I think I'll get one, it hasnt gone wrong in 56k miles. got 30k miles from last set of tyres as well.35 quid a tank from empty and does nearly 450 miles on a tank with a light foot. 35 quid road tax......
see where I am going on this.
SELL THE AUDIS and get a noddy car
I'll have dry feet and a few quid left in my pocket
ok, spoken to body shop, taking Archie in this afternoon, go home and swap wheels on the RS.... THANKS Mum She'll follow me to body shop then take me home
Old 02-11-09, 03:40 PM   #10
SteveCat
SteveCat's Avatar
Default .
Know absolutely nich about Type 85s matey,but may I suggest your door seals??
Had a real bad one on the 480 and tried sunroof drains and all places bulkhead !
Nien,turned oot to be a humble door johnny!
Oh,and dont forget the golden rule for keeping a classic....
LOCATION LOCATION LOCATION!!!
Mercedes E220 Sportline Coupe
Officially Pissed off with the snow... Isimmo General Chat 23 15-01-10 04:05 AM
Bloody rain!!! Coxy General Chat 10 17-05-09 02:17 PM
Its not all rain... Octanejunkie General Chat 0 04-08-08 10:15 PM
