Classic Audi » Technical » Mech/Tech » Engine » ur quattro boost setting WR engine
Old 22-10-09, 10:18 PM   #1
Darron Edwards
Darron Edwards's Avatar
Default ur quattro boost setting WR engine
Does anybody know the exact turbo boost pressure to attain 200 bhp and what pressure in psi does the cut out come in at on the ECU. I,m led to believe that the correct value for 200 bhp is 10.4 psi .Cheers Daz
Old 22-10-09, 10:30 PM   #2
Boost test and settings for a standard WR
Run engine until normal operating temp
With pressure gauge attached, accelerate at full throttle in 2nd gear, hold vehicle speed constant with foot brake when engine reached 5500rpm...
Do not exceed for more than 10secs...
Pressure is ambient temperature dependent
At 10deg ambient it is between 10.3psi and 9.6psi for a standard engine.
Old 22-10-09, 10:38 PM   #3
Darron Edwards
Thanks for the info matey. Daz
S6 Boost?? Booty Engine 6 11-11-09 11:27 PM
Where is my boost gone? quattrokid Engine 6 20-09-09 11:07 AM
Help to locate boost hissing noise 20vcqdriver Engine 22 18-07-09 11:50 PM
Exhaust on, just another boost leak to sort 20vcqdriver General Chat 2 15-07-09 12:31 PM
boost at 1.1bar constant 100turbo c Engine 4 26-03-09 09:04 PM
