Members: 19,817 | Total Threads: 40,093 | Total Posts: 471,108 Currently Active Users: 12608 (2 members and 12606 guests) Welcome to our newest member, Azinodeek |
The fuel pipes (braided steel ones) from the KE-JET metering head to injectors are well corroded (well the ends are). How important is this, and can I get new ones made up???
Steve |
My underneath fuel pipes have been replaced by copper and passed an mot
Think you can get all the fuel braided ones repaired, you just need a fuel injection specialist .....I do stand to be corrected though if anyone knows better. |
is there a question mark over copper fuel lines then?
Part of the rear of my return pipe went a bit leaky, I just cut it off and replaced the flexible with a piece 18" longer ! I did wonder about Kneifer pipe( spelling? ) but didn't get beyond thinking....... I'm sure that it is stronger than the 'ordinary' copper pipe. |
Mr Typ 43!
I replaced all of my solid fuel lines with 8mm copper heating pipe. It is perfect dimensionally and soft to create the flanges at the joints (I also used a sealer available from Frost's). Copper pipe should withstand at least 300psi and Jetronic runs at 75psi. Flexi pipe is fine as far as I know but I went for copper to try and keep it as original as possible - the colour looks nice too!
#5 | |
http://www.cunifer.com/ |
Mr Typ 43!
Brake pipes are way too small, the proper flanging tools are expensive - I used a £4.99 eBay purchase to do mine...
Thanks, I'll file this away for the right time !
The pipes I need are only available from main stealers at £53.50 EACH + VAT!!!
I'm going to contact Pirtek to see if they can do anything cheaper: http://www.pirtek.co.uk/pdf/catalogu..._section03.pdf Will let you know. Steve |
Pirtek said the pipes are too small, spoke to a mate who popped round on Friday, he got a fuel pipe for his Aprilia made up at a motorsport place near Castle Combe circuit for a fraction of the main dealer price.
Will try them in the new year. |
| Audi 100 NF engine KE Jet fuel pipes poss AAR | pimpdriver | Parts Wanted | 2 | 25-04-15 06:24 PM |
| sandwich plate & oil pipes foruse with a Mocal oil cooler | Gaz | Parts Wanted | 1 | 28-01-10 09:11 AM |
| Fuel lines rusty | pimpdriver | Engine | 5 | 25-04-09 06:50 PM |
| Audi 100 NF engine KE Jet fuel pipes | pimpdriver | Parts Wanted | 0 | 30-03-08 10:46 PM |
| Audi 100 NF engine KE Jet fuel pipes | pimpdriver | Parts Wanted | 1 | 29-01-08 11:45 AM |
