Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,133 Currently Active Users: 4939 (0 members and 4939 guests) Welcome to our newest member, BuddyInons |
My odometer doesn't work on my new car so i'm after some replacement clocks. The car is a 1989 90q. The clocks have 3 connectors, blue, yellow and white and it has mini-check. I'm not too bothered what mileage the new ones have on them as long as they work. Cheers
Are you sure? Should be autocheck, is the speedo rated to 160mph?
the one that checks the brake lights. Been a couple of years since i've had one with it. Might have got the name wrong. Not sure on the speedo, i'll check tomorrow
Thats ok, that is the autocheck, was thinking you maybe had the wrong clocks altogether, have you checked the fuses by any chance?
the speedo is 160mph. The rest of the gauges work ok but i'll check the fuses anyway.
If the rest of your gauges work and it is just the odometer that's not working, chances are that the odometer gear is broken. Not a very hard item to fix: http://www.humanspeakers.com/audi/odometer.htm
