-   -   B3 90q clocks (http://www.classic-audi.co.uk/forum/showthread.php?t=19849)
iconauto 23-10-11 10:20 PM
B3 90q clocks
My odometer doesn't work on my new car so i'm after some replacement clocks. The car is a 1989 90q. The clocks have 3 connectors, blue, yellow and white and it has mini-check. I'm not too bothered what mileage the new ones have on them as long as they work. Cheers:tup:
dgacampbell 23-10-11 10:41 PM
Are you sure? Should be autocheck, is the speedo rated to 160mph?
iconauto 23-10-11 10:46 PM
the one that checks the brake lights. Been a couple of years since i've had one with it. Might have got the name wrong. Not sure on the speedo, i'll check tomorrow
dgacampbell 23-10-11 10:55 PM
Thats ok, that is the autocheck, was thinking you maybe had the wrong clocks altogether, have you checked the fuses by any chance?
iconauto 24-10-11 11:59 AM
the speedo is 160mph. The rest of the gauges work ok but i'll check the fuses anyway.
Audicted 24-10-11 11:20 PM
If the rest of your gauges work and it is just the odometer that's not working, chances are that the odometer gear is broken. Not a very hard item to fix: http://www.humanspeakers.com/audi/odometer.htm
