Classic Audi » Classifieds section » Parts Wanted » B3 90q clocks
Old 23-10-11, 10:20 PM   #1
iconauto
Default B3 90q clocks
My odometer doesn't work on my new car so i'm after some replacement clocks. The car is a 1989 90q. The clocks have 3 connectors, blue, yellow and white and it has mini-check. I'm not too bothered what mileage the new ones have on them as long as they work. Cheers
iconauto is offline   Reply With Quote
Old 23-10-11, 10:41 PM   #2
dgacampbell
dgacampbell's Avatar
Are you sure? Should be autocheck, is the speedo rated to 160mph?
dgacampbell is offline   Reply With Quote
Old 23-10-11, 10:46 PM   #3
iconauto
the one that checks the brake lights. Been a couple of years since i've had one with it. Might have got the name wrong. Not sure on the speedo, i'll check tomorrow
Old 23-10-11, 10:55 PM   #4
dgacampbell
Thats ok, that is the autocheck, was thinking you maybe had the wrong clocks altogether, have you checked the fuses by any chance?
Old 24-10-11, 11:59 AM   #5
iconauto
the speedo is 160mph. The rest of the gauges work ok but i'll check the fuses anyway.
Old 24-10-11, 11:20 PM   #6
Audicted
If the rest of your gauges work and it is just the odometer that's not working, chances are that the odometer gear is broken. Not a very hard item to fix: http://www.humanspeakers.com/audi/odometer.htm
Audicted is offline   Reply With Quote
