Classic Audi » Technical » Mech/Tech » Engine » Running hot problem, please HELP!
Old 15-11-09, 05:17 PM   #1
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
Angry Running hot problem, please HELP!
Hello all
You may not have seen much activity from me on here recently, I've been busy fixing up the 200 turbo and getting your Christmas pressies sorted out - the 2010 calendar!
Anyway...I need your help! The 200 turbo is running too hot when driving at slow speeds and when stationary. Since I've bought it and the problem becoming apparent, I thought it would be a good idea to flush the radiator completely and put new antifreeze in (stuff that was in there was bright green! ) and have fitted a new fan switch (thought it may be faulty and not working on the first speed).
Nothing has changed...it's still the same. The fan cuts in at three quarters by which point it's pretty hot and struggles to get the temperature down (just stays in the same position). Once the car is turned off, it'll sit there for 10-15 minutes with the fan on until it's cool again. It can't be the thermostat because it warms up normally and sit's between a quarter and a half when driving normally.
The good news is the fact that it's never actually overheated, just runs hot! Has anyone got any ideas? Starting to pull my hair out over this one!
Thanks
Old 15-11-09, 05:55 PM   #2
4v6
What temps the thermostat supposed to open at and does yours do it?
Old 15-11-09, 06:20 PM   #3
have a look at this excellent website:
http://www.sjmautotechnik.com/troubl...lec.html#after
http://www.sjmautotechnik.com/troubl...ing.html#after
Steve
Old 15-11-09, 07:28 PM   #4
86audicoupe
Thanks for your replies! Lots of info there, going to check the relay and fuses first. From reading the article pimpdriver, it seems that the lower speed isn't cutting in when it should be and the high speed comes in (sounds like the car is going to take off!) at three quarters. Going to check a few more things and I will return...
Wish me luck!
Old 15-11-09, 07:36 PM   #5
Are u sure your A200 really have cooling fan slow speed function? How much pins have that fan switch u installed - two or three? And how much wires have connector?
From what material is your radiator made?
Old 15-11-09, 07:45 PM   #6
dandan
big gimping
dandan's Avatar
hahaha had a similar problem once in a polo coupeS just whack the heater on full blast and get ya windows down, it sucks all the hot air off the engine (it does work!) that was until i went and bought a new fan
dandan is offline   Reply With Quote
Old 15-11-09, 10:33 PM   #7
Woodsman
I was just going to ask you if you'd sorted it, obviously not.
If the fan is only cutting in at full speed, and not at mid speed first. I'd check the fan resistor, mounted infront of and below the rad, that link that pimpdriver put up tells you how to check this.
Glad I read that, as I was going to fit a lower temp fan switch (golf mk3) but if mpg suffers I won't be bothering.
Woodsman is offline   Reply With Quote
Old 15-11-09, 10:36 PM   #8
If it's not overheating, don't worry about it!
Old 15-11-09, 10:38 PM   #9
steveb
steveb's Avatar
you might have a partialy blocked rad
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 15-11-09, 10:40 PM   #10
could it be air in the rad??
Running probs vag80 Engine 9 30-07-09 06:33 AM
running problems Amar Engine 25 19-05-09 08:33 PM
Anyone Running LPG? Jabber General Chat 0 13-01-09 08:34 PM
anyone running after market ecu on 10v? sam Engine 5 03-01-09 10:33 PM
