Classic Audi » Technical » Mech/Tech » Engine » 10vT or 20vT? decisions decisions.
Old 23-02-08, 07:55 PM   #1
Gaz
Gaz's Avatar
Cool 10vT or 20vT? decisions decisions.
What would be easier to fit to my CQ? a 10VT or 20VT like a 3b or something.
i know the difference in cost of buying the engines, but will the installation of a 10VT be easier than trying to fit a 3b etc? not to mention cheaper.
what kind of difference are we talking? or will a lot have to change on my car to fit 'either' engine?
I'm thinking the 10vt will be a lot less hassle. but the 20vt has more power/potential.
Old 23-02-08, 08:38 PM   #2
Welcome Gaz, first of the random questions!
Jogi730 has a 20V in his.
What do you actually want? How much power? Will you actually get round to doing it?
Have you considered 7A or 2.5 N/A 10V?
Old 23-02-08, 08:57 PM   #3
Ease of fitment 10 valver. Max power attack- 20 valver.
Chap in the states (jared? Javed? ) was running 500bhp on a 10 valver for some time.... not to be ruled out in the persuit of grunt id say.
10 valvers got less moving parts, less complex but less overall scope for power.
Swings and roundabouts and really depends as others have said, re, what youre looking to accomlplish.
Old 23-02-08, 09:39 PM   #4
Gaz
Gaz's Avatar
i want more power.. my friend has a mk6 escort gti with a 2.0L zetec, gas flowed & skimmed head, rs2000 injectors, 1.8 head.. induction/exhaust and all that effort and money has given him about 155 bhp.
his car pulls away from me with ease! kind of embarrassing.. but i'm willing to bet i can get more bang for buck with a 10vt transplant and maybe even end up spending less money than he has on his escort.
basically i want to go faster. but maybe not spend quite as much money as some people have on there 20vt !
there's a 10vt for sale on here? correct? will that give me UR quattro power? (200bhp?)
and will it bolt in with very little effort? as far as NOT needing new/custom mounts? etc
will exhaust mount up ok? And what can i do if the ex-manifold fails/cracks?
basically i'll be quite happy with 200 bhp ATM. just so long as it works out MUCH cheaper in total cost than going down the 20vt scenario.
And if there's a bit of room for improvement later on, with out going OTT in spending than that will suit me fine. I'm not looking to smoke any super cars, just maybe keep up with standard cossie or two.
what do you think?
Old 23-02-08, 10:10 PM   #5
To be expected. Its a lighter car with less transmission losses and more power.
But, put him on the strip next to your stock Kv in the wet and see where he ends up .
Believe it or not its perfectly possible to do a turbo conversion on your current engine as long as the boost is kept manageable due to the higher compression a kv runs ( 10:1).
Maybe you just need a low pressure setup, basically an add on turbo and manifold to give you a 5psi kick.
If you go to the full Ur setup youre going to need the ecu etc to run the KE electronics or go to a standalone system like megasquirt etc, which is ramping up your costs.
Amen to that!
Power costs money unfortunately.
Should physically bolt right in, but youre going to have to get around the issues of the injection system.
Exhaust should slot right in if its from the Ur or 200t from the downpipe.
Ex manifold isnt a problem even if it cracks, they can be repaired...ive got cast iron rods and a tig, mig and stick welder so thatd be no real difficulty, bros an *ace* welder too.
what do you think?
Well if youre handy with the spanners and can do your own fab, electrics etc then you can do most anything and do it cheaply, whether or not youll have enough committment to see it through is entirely another thing as is money.
Old 23-02-08, 11:01 PM   #6
Hmmm if you 200 bhp then buy one as it will be cheaper than trying to convert
Old 24-02-08, 12:32 AM   #7
Megsy
I would save the money up and do the 20v transplant all day long.270 easy with a couple of chips.
Megsy is offline   Reply With Quote
Old 24-02-08, 09:43 AM   #8
Puglife
==>PUGSPORT!<==
Puglife's Avatar
if you can convert yourself then a 10vT will be cheaper by a long long way...
300bhp from a 10vT is very very easy... Engines aren't overly priced like 20v's and its essentially your engine with a turbo and extra components so fitment is straight in.
With 10v's you want to convert to EFi over the Kjet to obtain good BHP, this can be done a number of ways to keep costs down.
10vT has a much better noise to it and low down grunt with a bit of lag for turbo power. But as said anything over 450bhp and i'd go 20vT
Old 24-02-08, 02:36 PM   #9
spink
If you can do the work yourself you could buy a 'package' of 20vt engine/loom/ecu and most of the bits for a grand,not hard to find if you know where to look.Standard exhaust isnt worth using.Just get a stainless system made up.Whichever way you go you will have to upgrade the brakes as the standards are pretty poor.
Plus you will need a different flywheel if going 20v.
EDIT just realised you are the same person who asked this question over on s2forum.Those links i posted yesterday have just about everything covered.
Old 24-02-08, 08:42 PM   #10
Gaz
Gaz's Avatar
how much would an efi system for my car cost? (on the cheaper side of things) lol
would i see any gains from my current setup? ( non turbo)
EDIT: yea.. i thought the 10 valve sounded more.. RAW compared to the 20 v. good to know its not just me who thinks that.
10vt turbopuika Parts Wanted 2 14-12-09 11:12 AM
Just a good dyno on a 10vt:D tommyboy General Chat 0 05-07-09 12:35 PM
One of lifes hard decisions! audi_kid General Chat 8 28-12-08 12:33 AM
Performance Tuning the 10vT engines.. wedgedout Engine 9 18-05-08 09:01 PM
