Classic Audi » Technical » Mech/Tech » Electrical problems » OBD adapter
Old 06-09-09, 08:14 AM   #1
moggies
moggies's Avatar
Default OBD adapter
S6 1996, Please could anybody assist with the 2x2 obd connector under the bonnet.
I would like to wire up a later dlc connector so I can use vag com instead of trying to locate an adapter off thief-bay.
Does anyone know the pinouts? Thanks
moggies is offline   Reply With Quote
Old 06-09-09, 08:34 AM   #2
Puglife
==>PUGSPORT!<==
Puglife's Avatar
There's a thread on s2forum, I've just wired the obd plug to a 16pin OBD2 plug for easy access to read ecu.
Old 06-09-09, 08:48 AM   #3
moggies
moggies's Avatar
Thanks for that
Old 06-09-09, 10:33 AM   #4
Puglife
==>PUGSPORT!<==
Puglife's Avatar
Theres 4 wires... K and L wires are diagnostics, then a power 12v and an earth. The K & L wires have eyelet terminals that attach to the fusebox panel. Wire colours may vary but usually:
Green/Red - L
White/Red - K
Old 06-09-09, 03:20 PM   #5
moggies
moggies's Avatar
Right, thanks again, I'm struggling with any and all of the electrics as I need to get hold of some info or a decent service manual. I have nothing to refer to. Do you have any suggestions, would rather keep away from Haynes if possible??
Old 06-09-09, 05:06 PM   #6
spink
would the engine wiring diagrams be of use to you?
Old 06-09-09, 05:45 PM   #7
moggies
moggies's Avatar
Sure thing that would be great as I have oil and temp gauge issues, anything greatly appreciated. Could you email them to me or include with the package when you send?
Many thanks
Old 06-09-09, 05:55 PM   #8
spink
heres everything i have for the AAN,if you cant view them well enough i can print them out for you
Old 06-09-09, 07:05 PM   #9
moggies
moggies's Avatar
Brilliant, thanks
Old 06-09-09, 10:34 PM   #10
Puglife
==>PUGSPORT!<==
Puglife's Avatar
Got full schematics here. Also just rewired a whole loom into type 85 rally recreation so have a list of all wires/colours/sizes/source and purpose.
Will redo a PDF with it all cleaned up and clarified if i get a chance.
