OBD adapter
S6 1996, Please could anybody assist with the 2x2 obd connector under the bonnet.
I would like to wire up a later dlc connector so I can use vag com instead of trying to locate an adapter off thief-bay. Does anyone know the pinouts? Thanks |
There's a thread on s2forum, I've just wired the obd plug to a 16pin OBD2 plug for easy access to read ecu.
Thanks for that
Theres 4 wires... K and L wires are diagnostics, then a power 12v and an earth. The K & L wires have eyelet terminals that attach to the fusebox panel. Wire colours may vary but usually:
Green/Red - L White/Red - K |
Right, thanks again, I'm struggling with any and all of the electrics as I need to get hold of some info or a decent service manual. I have nothing to refer to. Do you have any suggestions, would rather keep away from Haynes if possible??
Sure thing that would be great as I have oil and temp gauge issues, anything greatly appreciated. Could you email them to me or include with the package when you send?
Many thanks |
heres everything i have for the AAN,if you cant view them well enough i can print them out for you
http://img.photobucket.com/albums/v255/spogger/Sch.jpg http://img.photobucket.com/albums/v2...ger/Sch1-1.jpg http://img.photobucket.com/albums/v2...r/NewImage.jpg http://img.photobucket.com/albums/v2...ger/Bigsch.jpg http://img.photobucket.com/albums/v2...NSchematic.jpg http://img.photobucket.com/albums/v255/spogger/Sch1.jpg |
Brilliant, thanks
Got full schematics here. Also just rewired a whole loom into type 85 rally recreation so have a list of all wires/colours/sizes/source and purpose.
Will redo a PDF with it all cleaned up and clarified if i get a chance. |
| All times are GMT. The time now is 08:56 AM. |
