Classic Audi » Technical » Mech/Tech » Engine » Hall Sender
Old 14-03-20, 09:40 PM   #1
Sie!
Default Hall Sender
I have a sneaky feeling my hall sender maybe on its way out, I've had intermittent stalling and non-starting, over a period of many years, gradually getting worse... Tried most other things apart from the coil itself - which I may try.
From reading the symptoms online it would figure.
Has anyone had any experience with replacing the sender as opposed to the whole distributor?
Also, the part numbers are a minefield, anyone know a definite distributor part number for a 1985 Audi 80, 1781cc DS motor?
Many thanks,
Sie!
Old 15-03-20, 11:22 AM   #2
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
Hi Sie
I had same symptoms as you and came across this website. Have a look here, I’m sure you’ll find what you need. Come with a decent warranty too. I copied and pasted their own part number into eBay and found they have an eBay shop which seems a bit cheaper
https://www.ignitioncarparts.co.uk/PartLists.aspx?
Old 17-03-20, 11:52 PM   #3
Sie!
Originally Posted by 86audicoupe View Post
Hi Sie
Ah I did come across that site, great to have your recommendation, and confirmation that I maybe on the right track to solving the problem - very helpful, many thanks
Old 15-03-20, 06:20 PM   #4
I've got a hall sender to fit to the distributor for my KV 90.
You need circlip pliers which is why I've been putting it off as I don't have the correct ones.
Looks like 034 998 065 is the right one providing you have 026 905 206 F distributor
I got mine from Amazon of all places. It was around £40 or so
1991 90 quattro
Old 17-03-20, 11:55 PM   #5
Sie!
Again, thank you! With that in mind, I may ensure a replacement complete distributor is available, then try my hand at just replacing the sender - sounds daft but I would like to try and retain as much of the original car as possible... after 35 years I’m not sure how much of my actual ‘Audi’ remains!
Old 18-03-20, 10:43 AM   #6
BackintheFold
BackintheFold's Avatar
Trigger's broom!
Old 18-03-20, 08:50 PM   #7
Sie!
Originally Posted by BackintheFold View Post
Trigger's broom!
Exactly,
Old 24-04-20, 07:39 PM   #8
I've had a go at replacing the hall sender on my KV distributor and got stuck fairly quickly.
rotor arm and dust cover off and there's a small circlip which holds the trigger wheel in. This circlip sits in a groove on the shaft.
Removed that easily enough.
There is a vertical groove on the shaft which acts as a key for a small pin for locating the trigger wheel in the correct place.
Trigger wheel is stuck solid and that pin isn't moving.
I'm wary about damaging the trigger wheel when trying to lever it up.
Any thoughts ?
The Haynes is its usual helpful self telling me to withdraw the trigger wheel with the pin. Probably easy 30 years ago.
1991 90 quattro
Old 24-04-20, 09:01 PM   #9
luapkram
luapkram's Avatar
Mike I am sure there is a specific long legged puller for removal of Hall Sender, but sorry I don’t have one
Sent from my iPad using Tapatalk
luapkram is offline   Reply With Quote
Old 24-04-20, 09:55 PM   #10
Ben
Can you remove the drive gear and pull the shaft out with the trigger wheel still attached?
1992 80 quattro 20vt
