Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » Sunroof Problem
Old 26-06-19, 04:12 PM   #1
jogi730
jogi
jogi730's Avatar
Default Sunroof Problem
The sunroof 0n my B2 Audi 90 has a problem opening and closing.
I thought the issue was mechanical. However, when the seal is not on, everything seems to work properly. As far as I know, the seal is an OE Audi replacement (fitted at least ten years ago).
Has anyone come across this problem? Any known fixes?
I have heard someone has some replacements, but these were ill-fitting and problematical too. Apparently, there is a GM that fits and works. Any experience of this? Part number?
Any advice would be appreciated.
Thanks in advance.
jogi730 is offline   Reply With Quote
Old 26-06-19, 06:47 PM   #2
tractor Dave
Mine wasn't closing properly so I took the seal off and cleaned it well then replaced using silicon grease to lubricate. All works nicely now. Worth a try.
Old 23-07-19, 07:44 PM   #3
BackintheFold
BackintheFold's Avatar
Similar question. I need to take my sunroof out. I’ve just bought a golf handle (which is in truth a little short, but will work) but when I try to wind it open it won’t move. It feels like one side is moving very slightly but not the other.
Any tips on how to get the roof out?
Can I pull the side clips out with the sunroof locked and then remove the roof? They are a bit stiff...
Once out I can clean everything but I can’t get it out (or at least I’m not prepared to force it more than I have so far)
Old 23-07-19, 09:12 PM   #4
tractor Dave
I don't think the pull tabs work until its raised.
I suggest you get some silicone spray and work it into the seal with a soft toothbrush. Leave it to soak overnight and hopefully it should free it up. The rubber has most likely glued itself to the bodywork. It gets very sticky as it degrades over time. Finding a new seal might be interesting.
Old 23-07-19, 09:43 PM   #5
BackintheFold
Thanks Dave.
I managed to insert a piece of thin plastic card between the seal and the roof, and ran it all the way round.
Then turned the handle, gently banged the roof, continued until it came clear.
Removed roof and cleaned junk out.
Good news is that the rust spots in the roof look more easily treatable than I thought, and the roof will work fine given some lubricant and exercise!
Old 24-07-19, 06:58 AM   #6
tractor Dave
Nice work
Old 24-07-19, 03:05 PM   #7
larry49
Good idea.........
larry49 is offline   Reply With Quote
Old 24-07-19, 03:08 PM   #8
larry49
I'm sure the roof has to be set in a certain position.......(for & aft), this is explained in the Bentley manual.
Old 24-07-19, 03:15 PM   #9
jogi730
jogi
jogi730's Avatar
I bought a brand new seal from quattro corner. It is a genuine Audi part. However, it seems the seal is slightly thick and despite being smothered with silicone grease as suggested, opening the sunroof remains a difficult procedure.
Having spoken to Ian, the older seals were thinner, but like is so often the case, these are NLA
