Members: 19,798 | Total Threads: 40,093 | Total Posts: 471,102 Currently Active Users: 1557 (0 members and 1557 guests) Welcome to our newest member, minihutera |
Probably not electrical, but the mileometer (trip and odometer) don't work.
Common problem. Easy fix?
Hit it, twice maybe.
1992 80 quattro 20vt |
take the clocks out and spray electrical contact spray on the connections, or slap the top of the dash hard, is it a tdi or petrol?
press the trip reset thingy a few times
Nothing of the above will work
Sorry pimp, it's common problem but there's no easy fix In these speedometers there's several plastic gears and one of them - the smallest one, of course, is prone to break one tooth. Solution - instrument cluster replacement [I guess most common fix here], just speedo clock replacement or, if there's spare gear [and I guess you don't have one] available, it's possible to change it, but it's troublesome, because arrow usually can't be removed - I've done this twice - fixed one B3's odometer with gear from my former speedometer [it's electronics malfunctioned], and one B4 - with gear from C3 "new" speedometer - luckily that small gear was identical, because everything else was not And in order to fix that B4 odometer, I had to cut off one not very needed mount with hot knife because otherwise it wasn't possible to open it enough... |
