-   -   Audi 80 B4 mileometer not working (http://www.classic-audi.co.uk/forum/showthread.php?t=16786)
pimpdriver 25-03-11 07:13 PM
Probably not electrical, but the mileometer (trip and odometer) don't work.
Common problem.
Easy fix?
Ben 25-03-11 07:40 PM
Hit it, twice maybe.
pimpdriver 25-03-11 10:05 PM
That is a typ44 speedo fix!!!
kully 26-03-11 08:00 AM
take the clocks out and spray electrical contact spray on the connections, or slap the top of the dash hard, is it a tdi or petrol?
type81 26-03-11 12:26 PM
press the trip reset thingy a few times
msh 26-03-11 12:48 PM
Nothing of the above will work :) Sorry pimp, it's common problem but there's no easy fix :nonod: In these speedometers there's several plastic gears and one of them - the smallest one, of course, is prone to break one tooth. Solution - instrument cluster replacement [I guess most common fix here], just speedo clock replacement or, if there's spare gear [and I guess you don't have one] available, it's possible to change it, but it's troublesome, because arrow usually can't be removed - I've done this twice - fixed one B3's odometer with gear from my former speedometer [it's electronics malfunctioned], and one B4 - with gear from C3 "new" speedometer - luckily that small gear was identical, because everything else was not :D And in order to fix that B4 odometer, I had to cut off one not very needed mount with hot knife because otherwise it wasn't possible to open it enough...
