Classic Audi » Technical » Mech/Tech » Engine » KV engine-what does this sensor control??
Old 16-02-11, 09:52 PM   #1
Default KV engine-what does this sensor control??
It's the sensor on the bottom of the pipe(Not top.),that goes from head to radiator?
What is this (temp) sensor(brown/black wire.) for and what does it control.
Thanks.
KARL.
Old 17-02-11, 07:14 AM   #2
KARL.
Old 17-02-11, 01:36 PM   #3
latent
latent's Avatar
is it the fan switch? Either that or maybe water temp gauge?
latent is offline   Reply With Quote
Old 17-02-11, 02:02 PM   #4
Sandro
Sandro's Avatar
Water temperature sensor. Gives signal to ECU or temp gauge - can't remember.
Old 17-02-11, 02:21 PM   #5
missfire
missfire's Avatar
i think it's a gear stick for small upside down monkeys..?
Old 17-02-11, 02:28 PM   #6
Phil Payne
Pull the wire off and see which one stops working.
Old 17-02-11, 03:56 PM   #7
Sandro
Sandro's Avatar
If it's for ECU - will not see it. It let's ECU to know - when to open cold start injector and extra air "valve" at the end of inlet manifold - holding on rubber pipes....
If it's for gauge - yes, You'll see it immidiately!
So logicaly - You'll understand for what it is
Old 17-02-11, 04:00 PM   #8
Only part connected to KV engine that could be called "ECU" is that small control unit, which controls ISV. Probably that sender is for it. For temp gauge and light should be the one which is on top - looks very familiar, the same as on B3 I4 engines.
Old 17-02-11, 05:00 PM   #9
20vcqdriver
20vcqdriver's Avatar
Thats the temp gauge sender . Line 30&155 of the drawings with a Blk/Brown wire. I was wrong see later comment....
Old 17-02-11, 06:30 PM   #10
I was thinking,exactly the same.
KARL.
