I believe you wrote 4AO instead of 4A0. Makes a big difference :nod:
brother had a 1997 a4 with same problem i ordered a repair kit on e-bay and took me 30 mins stripping it and replacing the parts, not compicated to do and done the job and a lot cheaper
So the first thing to do is disconnect the hose from the pump and check the vacuum integrity with a MityVac or similar. |
I recommend it for ur-quattro owners especially because the stock system doesn't lock the car from the passenger door, only from the driver's door. |
| All times are GMT. The time now is 07:40 PM. |
