Classic Audi » Classifieds section » Parts Wanted » Central Locking Pump
Old 24-10-11, 02:03 PM   #1
k10mistry
Default Central Locking Pump
Hello Everyone, Just wanted to know if anyone has a central Locking Pump part no: 4AO862257A.
Ebay don't have any with that part number, google give me german websites? I took the pump to a electrician he said the pump has totally burn't out and so has the circuit board as well.
Please can anyone help??
k10mistry is offline   Reply With Quote
Old 24-10-11, 02:12 PM   #2
stuartmmcfc
whats it for?
I'm sure someone with access to ETKA will advise you better, but I found on my ur that there were several pumps with differing part numbers that worked fine.
Old 24-10-11, 02:16 PM   #3
k10mistry
Its for a 1992 Audi Coupe 2.8 Quattro
Audi have just said they they are £298 + VAT
OMG!!!
Old 24-10-11, 02:42 PM   #4
davow
davow's Avatar
pm sent
davow is offline   Reply With Quote
Old 24-10-11, 03:17 PM   #5
Phil Payne
Banned
OMG!!!
You can get five-wire actuators from Maplins for a tenner a door. Chuck the pump away.
Old 24-10-11, 04:12 PM   #6
Ringmaster
Ringmaster's Avatar
Phil,
Would this be a solution for those of us with a central locking system such as my C3 has?
Old 24-10-11, 04:23 PM   #7
k10mistry
Cheers Phil thanks for the solution but I would like to keep the car in its original state!
Thanks for your help though!
Old 24-10-11, 04:28 PM   #8
Hanuman
Hanuman's Avatar
The electrical actuators are an option, but only if you understand what you wish to do; how to wire them in correctly, and have decent tools to do the job reliably. There is no point in swapping one problem for another.
to K10.....
the first part of your pump part number is 4A0862257A, which sort of links t to the chassis.
I wonder if there is any commonality between al the pumps fitted to the audis of a certain era.
(anybody...?)
My V8 has 443862257H according to VAGCAT.
I broke a V8 last year, and have a pump in my spares. But not immediately to hand.
A photo of yours might help.
You show me yours, and i'll show you mine if I get a chance.
Old 24-10-11, 05:46 PM   #9
Hanuman
Hanuman's Avatar
What is worth investigating prior to fitting a new pump, is the cause of the total failure of the old.
Is it old age, or problems in the hoses and other bits resulting in the pump failure? It would not be good to fit a new one if the same were to happen.
Old 24-10-11, 11:12 PM   #10
Audicted
According to ETKA your part number is 4A0862257J, (not A) and this part number is common across B3's and B4's from 1989-1996 (Coupes, Sedans and Avants including RS2) and C4's from 1992-1997, the A8 from 1994-1999 and the V8 from 1989-1994.
Check your part number again.
Audicted is offline   Reply With Quote
