Classic Audi » Technical » Mech/Tech » Wheels & Tyres » Tyre Size
Old 06-02-10, 09:38 AM   #1
type81
type81's Avatar
Default Tyre Size
my audi 80 has the 6x14 45et ronals with 185 60 14 tyres, if i were to go 1 up to the 7x15 42et then i can use 195 50 15 tyres, is this correct??
Old 06-02-10, 09:45 AM   #2
you should use 195/55/15 you can use 50s for a lower profile but you speedo will be out
Old 06-02-10, 09:51 AM   #3
type81
type81's Avatar
interesting, i always thought that an inch bigger in wheel size and you decrease the profile by 10
Old 06-02-10, 09:52 AM   #4
dont forget you are also going from 185 to 195
Old 06-02-10, 10:03 AM   #5
type81
type81's Avatar
But thats the witdh, that wudnt really affect the rolling radius profile speedo thingy, wud it?
Old 06-02-10, 10:14 AM   #6
the 50 or 55 is a percentage of the tread
so a 135 / 50 is not the same as a 155 /50 the 50 is not the same on all tyres its only a percentage so all are differant diameters
just get a spare tyre take it to a fitting place and put them side by side and look at the hight differance .
Old 06-02-10, 10:21 AM   #7
type81
type81's Avatar
thanks micky
Old 06-02-10, 10:37 AM   #8
Martc
Black Coupe Collector
Martc's Avatar
You have two options
195/55/15's
or
205/50/15's
I would go for 195/55/15's which is what is going on my 7jx15 ET42 Ronals
95 UrS6
87 Coupe Quattro
Old 06-02-10, 10:47 AM   #9
type81
type81's Avatar
theres no power steering so 195' is what il go for, yep them ronals are nice
Old 06-02-10, 03:47 PM   #10
Stop: wrong.
185/60R14 = 578mm diameter
195/50R15 = 576mm diameter (-0.35% difference)
195/55R15 = 596mm diameter (+3.11% difference)
http://www.etyres.co.uk/tyre-size-calculator.htm
Don't get 55 profile, your speedo will be out, 50 profile is correct........
