Members: 19,730 | Total Threads: 40,088 | Total Posts: 471,062 Currently Active Users: 9221 (0 members and 9221 guests) Welcome to our newest member, Jonathanirorb |
Last August I had a new timing belt etc fitted ( Gates ) I have only driven about 1200 miles now I have a metalic noise coming from the timing belt cover, the garage told me it is guaranteed for 2 years, I took it back to the garage last Wednesday and they said that they had fixed it, it was the alternator belt they said, but I still have the noise so does the guarantee cover the parts and labor or just parts?
Thanks for your help! ![]() |
#2 | |
TBH you would be better talking to the garage and if your not happy have a chat with Trading Standards who are very helpful in my experience. |
I replaced a cambelt on a Zafira recently with a Gates kit.
The customer came back a week later with a noisy engine, the tensioner bolt supplied in the kit had failed and the engine jumped a tooth ![]() I contacted my supplier who called gates who sent out an engineer to assess the damage. He agreed that the bolt had not been over tightened and that it was component failure, all i had to do was invoice Gates for the parts and labour on the job and send them the old broken parts. They paid the whole lot, new valves, gaskets, etc but the customer was without the car for a fortnight while it was all sorted. I would take it back to the garage and get them to check out the noise as soon as poss, and if you could be there when it is stripped then that would be better.They need to remove and check the tensioners for any play, or damaged bolts (maybe they reused the old bolts...... )As far as i know gates don't sell cambelts on their own just in a kit with tensioners/bolts etc. I know garages including main stealers!!! that don't replace the tensioners/water pumps(when they are driven by the cambelt)and this is when the fookups occur. |
Banned
If the parts used were genuine there is a full warrenty for parts and labour - but usually this warrenty work would be carried out by the parts supplying dealer rather than the wprkshop that fitted the bits.
However it happens though, you should incur no cost if indeed a new parts has suffered some sort of failure. Your workshop has a duty of care to rectify the issue, whether that means they do it or Audi does it is not important but you should be paying nothing. If you are told "another" part has failed instead, be sure to ask to see proof of the failing. One thing to mention, if it IS a noise from the timing belt drive get it checked quickly - if the belt fails and you were aware of an issue but continued to use it, you may struggle to get the damage costs covered |
I'm cautious about saying this without seeing the car, so please bear in mind it's just an idea. I changed the timing belt on my BMW last year, and not long after, I noticed a noise. I checked it out, by taking off the alternator and PAS belts and briefly running the engine. Noise went away. It turned out to be the alternator bearings that were noisy.
better to be safe not sorry change the cambelt and everything arioud it eg tensionser water pumps gaskets etc etc etc
Was this on a 5 cylinder engine as the water pump should also get changed at the same time on these as it is used as the tensioner, if it is it sounds like they may have overtensioned the belt and wrecked the water pump bearing. If its a 4 cylinder ignore everything I've said
Following on about this timing belt, I went back to the garage they said it was the alternator belt too tight but after this noise was still there, so took the car back yesterday and asked them to check while I was there so the mechanic started to take off the timing belt cover but the top cover would not come off because he said the bottom cover had moved and it was touching the top cover so stopping it from coming off. They were the last to touch it when they replaced the belt, so I couldn't wait so left and am waiting for them to call me now, they keep saying the noise is normal! Anyone have any idea's about this?
#9 | |
Anything that's regarded as a "noise" is NOT normal. Some garages just talk a lot of B*llocks! ![]() ![]()
B5 RS4 88 Pearl White MB Ur quattro |
| Timing belt probs. | PhilGee | Engine | 8 | 24-05-10 06:47 PM |
| timing belt audi 100 turbo | sam | Parts Wanted | 0 | 16-05-09 08:53 AM |
| Timing Belt | poopcoupe | Technical Info | 10 | 15-04-09 08:17 PM |
| Timing belt and Oil filter... | slick578 | Engine | 2 | 17-04-08 10:24 AM |
