Classic Audi » Classifieds section » Parts Wanted » type 85 80/90 sunroof panel
Old 09-12-09, 06:25 AM   #1
peanut
Default type 85 80/90 sunroof panel
as per title,
anyone happen to have a sunroof panel for a type 85 80/90. Ideally with mech but id take one without.
Just to add the coupe ones are different and wont fit
Thanks
Gav
Old 09-12-09, 09:14 AM   #2
If you're not fussed about tilt and slide, Mk2 Golf ones should fit.
I sold my sunroof to a Mk2 Golf boy as the Audi 80 ones tilt and slide, but the Mk2 Golf ones only tilt........
Old 09-12-09, 10:45 AM   #3
Other way round isn't it ?
My Mark 2 Golfs both had sunroofs and they both slid open but didnt tilt
Old 09-12-09, 11:09 AM   #4
you're right, I was confused!
But the panel should be the same???
Old 09-12-09, 09:38 PM   #5
peanut
aye theyre the same size but not sure if theyre interchangable between the mk2 and audi mechs
cheers
Gav
Old 09-12-09, 09:43 PM   #6
Corrado....
Old 09-12-09, 09:49 PM   #7
peanut
sod that, ive had 12 corrados and ive had to fix the bloody sunroof on every single one. 11 of them ive fitted passat estate panel and mechs too as theyre a straight swap.
Do corrado mechs.panels bolt straight up to the 80/90? id beinterested if they did as i can then convert mine to electic sunroof
Thanks, you given me an idea now
Gav
Old 09-12-09, 10:10 PM   #8
Acidburn
The original sin
Acidburn's Avatar
passat one's should be an easy find and could get a glass one.
80 tdi avant
Old 09-12-09, 10:36 PM   #9
B2 80/90 fit into Mk2 with the mechanism, so if you get a Mk2 Golf one, with the mechanism, it should fit your B2..........
Old 09-12-09, 11:06 PM   #10
Lets put it this way, the seal is the same part, my brothers 86GT has a Corrado seal, just reversed on fitment, inside is outside, if you get my drift.
Type 85 sunroof seal ian20v Parts Wanted 8 04-02-10 06:55 PM
Audi 80 sport type 81, Door strip panel type81 Parts Wanted 1 12-12-09 06:09 PM
t85 sunroof panel peanut Bodywork, glass & exterior fitments 3 05-12-09 09:01 PM
Sunroof panel and mechanism. 4v6 Parts Wanted 0 27-06-09 06:30 PM
Sunroof Seal 86audicoupe General Chat 4 10-03-08 07:40 PM
